Energy balance
Energy balance
Local variables to be added
The following local variables need to be defined for the examples in this section:
integer iel , ifac , ivar
integer iel1 , iel2 , ieltsm
integer iortho
integer inc , iccocg
integer iflmas , iflmab , ipccp
integer iscal
integer ilelt , nlelt
double precision xvara , xvar
double precision xbilan , xbilvl , xbilpa , xbilpt
double precision xbilsy , xbilen , xbilso , xbildv
double precision xbilmi , xbilma
double precision xfluxf , xgamma
double precision flumab , ctb1, ctb2
integer, allocatable, dimension(:) :: lstelt
double precision, allocatable, dimension(:,:) :: grad
double precision, allocatable, dimension(:) :: treco
double precision, allocatable, dimension(:) :: xcp
double precision, dimension(:), pointer :: imasfl, bmasfl
double precision, dimension(:), pointer :: coefap, coefbp, cofafp, cofbfp
double precision, dimension(:), pointer :: crom
double precision, dimension(:), pointer :: cpro_visct, cpro_cp
double precision, dimension(:), pointer :: cvar_scal, cvara_scal
The following initialization block needs to be added for the following examples:
! Allocate a temporary array for cells or interior/boundary faces selection
allocate(lstelt(max(ncel,nfac,nfabor)))
allocate(xcp(ncel))
Ad the end of the subroutine, it is recommended to deallocate the work array:
! Deallocate the temporary array
deallocate(lstelt)
deallocate(xcp)
In theory Fortran 95 deallocates locally-allocated arrays automatically, but deallocating arrays in a symmetric manner to their allocation is good practice, and it avoids using a different logic for C and Fortran.
Body
This example computes energy balance relative to temperature We assume that we want to compute balances (convective and diffusive) at the boundaries of the calculation domain represented below (with boundaries marked by colors).
The scalar considered if the temperature. We will also use the specific heat (to obtain balances in Joules)
Domain and associated boundary colors:
To ensure calculations have physical meaning, it is best to use a spatially uniform time step (idtvar = 0 or 1). In addition, when restarting a calculation, the balance may be incorrect at the first time step.
Temperature variable
Boundary coefficients coefap/coefbp are those of ivarfl(ivar).
The balance at time step n is equal to:
\[ \begin{array}{r c l} Balance^n &=& \displaystyle \sum_{\celli=1}^{\ncell} \norm{\vol{\celli}} C_p \rho_\celli \left(T_\celli^{n-1} -T_\celli^n \right) \\ &+& \displaystyle \sum_{\fib} C_p \Delta t_\celli \norm{\vect{S}_\ib} \left(A_\ib^f + B_\ib^f T_\celli^n \right) \\ &+& \displaystyle \sum_{\fib} C_p \Delta t_\celli \dot{m}_\ib \left(A_\ib^g + B_\ib^g T_\celli^n \right) \end{array} \]
The first term is negative if the amount of energy in the volume has increased (it is 0 in a steady regime).
The other terms (convection, diffusion) are positive if the amount of energy in the volume has increased due to boundary conditions.
In a steady regime, a positive balance thus indicates an energy gain.
With $ \rho $ (rom) calculated using the density law from the usphyv subroutine, for example:
\[ \rho^{n-1}_\celli = P_0 / \left( R T_\celli^{n-1} + T_0 \right) \]
where $ R$ is cs_physical_constants_r and $ T_0 $ is tkelv.
$ C_p $ and $ \lambda/C_p $ may vary.
! The balance is not valid before running at least one time step.
if (ntcabs.eq.ntpabs) then
! 2.1 Initialization
! --> Local variables
! xbilvl: volume contribution of unsteady terms
! xbildv: volume contribution due to to term in div(rho u)
! xbilpa: contribution from adiabatic walls
! xbilpt: contribution from walls with fixed temperature
! xbilsy: contribution from symmetry boundaries
! xbilen: contribution from inlets
! xbilso: contribution from outlets
! xbilmi: contribution from mass injections
! xbilma: constribution from mass suctions
! xbilan: total balance
xbilvl = 0.d0
xbildv = 0.d0
xbilpa = 0.d0
xbilpt = 0.d0
xbilsy = 0.d0
xbilen = 0.d0
xbilso = 0.d0
xbilmi = 0.d0
xbilma = 0.d0
xbilan = 0.d0
iscal = iscalt ! temperature scalar number
ivar = isca(iscal) ! temperature variable number
call field_get_val_s(ivarfl(ivar), cvar_scal)
call field_get_val_prev_s(ivarfl(ivar), cvara_scal)
! Physical quantity numbers
call field_get_val_s(icrom, crom)
call field_get_val_s(ivisct, cpro_visct)
! Pointers to the mass fluxes
call field_get_key_int(ivarfl(ivar), kimasf, iflmas)
call field_get_key_int(ivarfl(ivar), kbmasf, iflmab)
call field_get_val_s(iflmas, imasfl)
call field_get_val_s(iflmab, bmasfl)
! The balance is in Joule, so store the specific heat when dealing
! with the Temperature.
if (icp.ge.0) call field_get_val_s(icp, cpro_cp)
! If it is a temperature
if (itherm.eq.1) then
if (icp.ge.0) then
do iel = 1, ncel
xcp(iel) = cpro_cp(iel)
enddo
else
do iel = 1, ncel
xcp(iel) = cp0
enddo
endif
else
do iel = 1, ncel
xcp(iel) = 1.d0
enddo
endif
! Boundary condition pointers for gradients and advection
call field_get_coefa_s(ivarfl(ivar), coefap)
call field_get_coefb_s(ivarfl(ivar), coefbp)
! Boundary condition pointers for diffusion
call field_get_coefaf_s(ivarfl(ivar), cofafp)
call field_get_coefbf_s(ivarfl(ivar), cofbfp)
! --> Compute value reconstructed at I' for boundary faces
allocate(treco(nfabor))
! For non-orthogonal meshes, it must be equal to the value at the
! cell center, which is computed in:
! treco(ifac) (with ifac=1, nfabor)
! For orthogonal meshes, it is sufficient to assign:
! cvar_scal(iel) to treco(ifac), with iel=ifabor(ifac)
! (this option corresponds to the second branch of the test below,
! with iortho different from 0).
iortho = 0
! --> General case (for non-orthogonal meshes)
if (iortho.eq.0) then
! Allocate a work array for the gradient calculation
allocate(grad(3,ncelet))
! --- Compute temperature gradient
inc = 1
iccocg = 1
call field_gradient_scalar &
(ivarfl(ivar), 0, imrgra, inc, iccocg, &
grad)
! - Compute reconstructed value in boundary cells
do ifac = 1, nfabor
iel = ifabor(ifac)
treco(ifac) = cvar_scal(iel) &
+ diipb(1,ifac)*grad(1,iel) &
+ diipb(2,ifac)*grad(2,iel) &
+ diipb(3,ifac)*grad(3,iel)
enddo
! Free memory
deallocate(grad)
! --> Case of orthogonal meshes
else
! Compute reconstructed value
! (here, we assign the non-reconstructed value)
do ifac = 1, nfabor
iel = ifabor(ifac)
enddo
endif
! 2.1 Compute the balance at time step n
! --> Balance on interior volumes
! If it is variable, the density 'rom' has been computed at the beginning
! of the time step using the temperature from the previous time step.
do iel = 1, ncel
xvara = cvara_scal(iel)
xvar = cvar_scal(iel)
xbilvl = xbilvl &
+ volume(iel) * xcp(iel) * crom(iel) &
* (xvara - xvar)
enddo
! --> Balance on all faces (interior and boundary), for div(rho u)
do ifac = 1, nfac
iel1 = ifacel(1,ifac)
if (iel1.le.ncel) then
ctb1 = imasfl(ifac)*xcp(iel1)*cvar_scal(iel1)*dt(iel1)
else
ctb1 = 0d0
endif
iel2 = ifacel(2,ifac)
if (iel2.le.ncel) then
ctb2 = imasfl(ifac)*xcp(iel2)*cvar_scal(iel2)*dt(iel2)
else
ctb2 = 0d0
endif
xbildv = xbildv + (ctb1 - ctb2)
enddo
do ifac = 1, nfabor
iel = ifabor(ifac)
xbildv = xbildv + dt(iel) * xcp(iel) &
* bmasfl(ifac) &
* cvar_scal(iel)
enddo
! In case of a mass source term, add contribution from Gamma*Tn+1
if (ncetsm.gt.0) then
do ieltsm = 1, ncetsm
iel = icetsm(ieltsm)
xgamma = smacel(ieltsm,ipr)
xbildv = xbildv &
- volume(iel) * xcp(iel) * dt(iel) &
* xgamma * xvar
enddo
endif
! --> Balance on boundary faces
! We handle different types of boundary faces separately to better
! analyze the information, but this is not mandatory.
! - Compute the contribution from walls with colors 2, 4, and 7
! (adiabatic here, so flux should be 0)
call getfbr('2 or 4 or 7', nlelt, lstelt)
do ilelt = 1, nlelt
ifac = lstelt(ilelt)
iel = ifabor(ifac) ! associated boundary cell
! Physical variables
flumab = bmasfl(ifac)
! Contribution to flux from the current face
! (diffusion and convection fluxes)
xfluxf = - surfbn(ifac) * dt(iel) &
* (cofafp(ifac) + cofbfp(ifac)*treco(ifac)) &
- flumab * dt(iel) * xcp(iel) &
* (coefap(ifac) + coefbp(ifac)*treco(ifac))
xbilpa = xbilpa + xfluxf
enddo
! Contribution from walls with color 6
! (here at fixed temperature; the convective flux should be 0)
call getfbr('6', nlelt, lstelt)
do ilelt = 1, nlelt
xbilpt = xbilpt + xfluxf
enddo
! Contribution from symmetries (should be 0).
call getfbr('1', nlelt, lstelt)
do ilelt = 1, nlelt
xbilsy = xbilsy + xfluxf
enddo
! Contribution from inlet (color 3, diffusion and convection flux)
call getfbr('3', nlelt, lstelt)
do ilelt = 1, nlelt
xbilen = xbilen + xfluxf
enddo
! Contribution from outlet (color 5, diffusion and convection flux)
call getfbr('5', nlelt, lstelt)
do ilelt = 1, nlelt
xbilso = xbilso + xfluxf
enddo
! Now the work array for the temperature can be freed
deallocate(treco)
! --> Balance on mass source terms
! We separate mass injections from suctions for better generality
! depending on the type of injection we use the 'smacel' value
! or the ambient temperature
if (itypsm(ieltsm,ivar).eq.0 .or. xgamma.lt.0.d0) then
else
xvar = smacel(ieltsm,ivar)
endif
if (icp.ge.0) then
if (xgamma.lt.0.d0) then
xbilma = xbilma &
+ volume(iel) * cpro_cp(iel) * dt(iel) * xgamma * xvar
else
xbilmi = xbilmi &
endif
else
xbilma = xbilma &
+ volume(iel) * cp0 * dt(iel) * xgamma * xvar
else
xbilmi = xbilmi &
endif
endif
enddo
endif
! Sum of values on all ranks (parallel calculations)
if (irangp.ge.0) then
call parsom(xbilvl)
call parsom(xbildv)
call parsom(xbilpa)
call parsom(xbilpt)
call parsom(xbilsy)
call parsom(xbilen)
call parsom(xbilso)
call parsom(xbilmi)
call parsom(xbilma)
endif
! --> Total balance
! We add the different contributions calculated above.
xbilan = xbilvl + xbildv + xbilpa + xbilpt + xbilsy + xbilen &
+ xbilso + xbilmi + xbilma
! 2.3 Write the balance at time step n
write (nfecra, 2000) &
ntcabs, xbilvl, xbildv, xbilpa, xbilpt, xbilsy, xbilen, xbilso, &
xbilmi, xbilma, xbilan
2000 format &
3x,'** Thermal balance **', /, &
3x,' ---------------', /, &
'bt ',' Iter', &
' Volume Divergence Adia Wall Fixed_T Wall Symmetry', &
' Inlet Outlet Inj. Mass. Suc. Mass. Total', /, &
'bt ', i6, 10e12.4, /, &
endif ! End of test on first time step
