Definition of physical variable laws. More...
Functions/Subroutines | |
| subroutine | usphyv (nvar, nscal, mbrom, dt) |
| Definition of physical variable laws. More... | |
| subroutine | usvist (nvar, nscal, ncepdp, ncesmp, icepdc, icetsm, itypsm, dt, ckupdc, smacel) |
| Modify turbulent viscosity. More... | |
| subroutine | ussmag (nvar, nscal, ncepdp, ncesmp, icepdc, icetsm, itypsm, dt, ckupdc, smacel, mijlij, mijmij) |
| user modification of the Smagorinsky constant in the case of a dynamic model More... | |
| subroutine | usvima |
| User subroutine dedicated the use of ALE (Arbitrary Lagrangian Eulerian Method): fills mesh viscosity arrays. More... | |
| subroutine | usatph |
| usatph More... | |
See Define user laws for physical properties for examples.
| subroutine usatph | ( | ) |
usatph
User subroutine dedicated to modifie physical properties of the atmospheric module
This subroutine is called at beginning of each time step at the end of atphyv.
| subroutine usphyv | ( | integer | nvar, |
| integer | nscal, | ||
| integer | mbrom, | ||
| double precision, dimension(ncelet) | dt | ||
It is forbidden to modify turbulent viscosity visct here (a specific subroutine is dedicated to that: usvist)
viscls.ro0)viscl0)Warning: if the scalar is the temperature, cpro_vscalt corresponds to its conductivity (Lambda) in W/(m K)
The types of boundary faces at the previous time step are available (except at the first time step, where arrays itypfb and itrifb have not been initialized yet)
It is recommended to keep only the minimum necessary in this file (i.e. remove all unused example code)
Cells may be identified using the getcel subroutine. The syntax of this subroutine is described in the cs_user_boundary_conditions subroutine, but a more thorough description can be found in the user guide.
| [in] | nscal | total number of scalars |
| [in] | mbrom | indicator of filling of romb array |
| subroutine ussmag | ( | integer | nvar, |
| integer | ncepdp, | ||
| integer | ncesmp, | ||
| integer, dimension(ncepdp) | icepdc, | ||
| integer, dimension(ncesmp) | icetsm, | ||
| integer, dimension(ncesmp,nvar) | itypsm, | ||
| double precision, dimension(ncelet) | dt, | ||
| double precision, dimension(6,ncepdp) | ckupdc, | ||
| double precision, dimension(ncesmp,nvar) | smacel, | ||
| double precision, dimension(ncelet) | mijlij, | ||
| double precision, dimension(ncelet) | mijmij | ||
SMAGOR = Mij.Lij / Mij.Mij
The local avergaes of the numerator and denominator are done before calling this subroutine, so
SMAGOR = < Mij.Lij > / < Mij.Mij >
In this subroutine, Mij.Lij and Mij.Mij are passed as arguments before the local average.
| [in] | ncepdp | number of cells with head loss |
| [in] | icepdc | head loss cell numbering |
| [in] | icetsm | numbering of cells with mass source term |
| [in] | itypsm | kind of mass source for each variable (cf. Examples of data settings for mass source terms (cs_user_mass_source_terms.f90)) |
| [in] | ckupdc | work array for head loss terms |
| [in] | smacel | values of variables related to mass source term. If ivar=ipr, smacel=mass flux |
| [in] | mijlij | mij.lij before the local averaging |
| [in] | mijmij | mij.mij before the local averaging |
| subroutine usvima | ( | ) |
Here one can modify mesh viscosity value to prevent cells and nodes from huge displacements in awkward areas, such as boundary layer for example.
This subroutine is called once per computation, before restart files are read, so the mesh is always in the initial position at this stage.
Note that by default, the mesh viscosity is initialized to a uniform value of 1.
| subroutine usvist | ( | integer | nvar, |
| double precision, dimension(ncesmp,nvar) | smacel | ||
This subroutine is called at beginning of each time step after the computation of the turbulent viscosity (physical quantities have already been computed in usphyv).
Turbulent viscosity
(kg/(m s)) can be modified.
A modification of the turbulent viscosity can lead to very significant differences betwwen solutions and even give wrong results.
This subroutine is therefore reserved to expert users.
