Generation of synthetic turbulence at LES inlets initialization. More...
Functions/Subroutines | |
| subroutine | cs_user_les_inflow_init (nent) |
| subroutine | cs_user_les_inflow_define (nument, typent, nelent, iverbo, nfbent, lfbent, vitent, enrent, dspent) |
Definition of the characteristics of the synthetic turbulence inlet nument. More... | |
| subroutine | cs_user_les_inflow_advanced (nument, nfbent, nvar, nscal, lfbent, dt, uvwent, rijent, epsent) |
| Generation of synthetic turbulence at LES inlets advanced mode. More... | |
See Generation of synthetic turbulence at LES inlets for examples.
nent and isuisy might be defined.
nent = Number of inlets isuisy = 1: Reading of the LES inflow module restart file = 0: not activated (synthetic turbulence reinitialized)
| subroutine cs_user_les_inflow_advanced | ( | integer | nument, |
| integer | nfbent, | ||
| integer | nvar, | ||
| integer | nscal, | ||
| integer, dimension(nfbent) | lfbent, | ||
| double precision, dimension(ncelet) | dt, | ||
| double precision, dimension(ndim,nfbent) | uvwent, | ||
| double precision, dimension(6,nfbent) | rijent, | ||
| double precision, dimension(nfbent) | epsent | ||
Accurate definition of mean velocity, Reynolds stresses and dissipation rate for each boundary face of the synthetic turbulence inlet nument
rijent components are ordonned as follows: 11, 22, 33, 12, 13, 23
Arrays are initialized before this subroutine is called by (see the user subroutine Caracteristics of one specific inlet):
| [in] | nument | id of the inlet |
| [in] | nfbent | numb. of bound. faces of the inlet |
| [in] | nvar | number of variables |
| [in] | nscal | number of scalars |
| [in] | lfbent | list of bound. faces of the inlet |
| [in] | dt | time step |
| [out] | uvwent | mean velocity at the inlet faces |
| [out] | rijent | turb. kin. ener. at the inlet faces |
| [out] | epsent | turb. dissipation at the inlet faces |
| subroutine cs_user_les_inflow_define | ( | integer | nument, |
| integer | typent, | ||
| integer | nelent, | ||
| integer | iverbo, | ||
| integer, dimension(nfabor) | lfbent, | ||
| double precision, dimension(3) | vitent, | ||
| double precision | enrent, | ||
| double precision | dspent | ||
For each LES inlet, the following parameters might be defined:
dspent : reference dissipation rate
| [out] | typent | type of inflow method at the inlet |
| [out] | nelent | numb. of entities of the inflow meth |
| [out] | iverbo | verbosity level |
| [out] | nfbent | numb. of bound. faces of the inlet |
| [out] | lfbent | list of bound. faces of the inlet |
| [out] | vitent | ref. mean velocity at the inlet |
| [out] | enrent | ref. turb. kin. ener. at the inlet |
| [out] | dspent | ref. turb. dissipation at the inlet |
| subroutine cs_user_les_inflow_init | ( | integer | nent | ) |
| [out] | nent | number of synthetic turbulence inlets |
