cs_turbulence_bc.h
1 #ifndef __CS_TURBULENCE_BC_H__
2 #define __CS_TURBULENCE_BC_H__
5  * Base turbulence boundary conditions.
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
45  * Type definitions
49  * Global variables
51
52 /*=============================================================================
53  * Public function prototypes
55
56 /*----------------------------------------------------------------------------*/
60 /*----------------------------------------------------------------------------*/
61
62 void
64
65 /*----------------------------------------------------------------------------*/
69 /*----------------------------------------------------------------------------*/
70
71 void
73
117 /*----------------------------------------------------------------------------*/
118
119 void
120 cs_turbulence_bc_ke_hyd_diam(double uref2,
121  double dh,
122  double rho,
123  double mu,
124  double *ustar2,
125  double *k,
126  double *eps);
127
147
148 void
150  double t_intensity,
151  double dh,
152  double *k,
153  double *eps);
154
155 /*----------------------------------------------------------------------------*/
189 /*----------------------------------------------------------------------------*/
190
191 void
193  double uref2,
194  double dh,
195  double rho,
196  double mu,
197  double *rcodcl);
198
199 /*----------------------------------------------------------------------------*/
212 /*----------------------------------------------------------------------------*/
213
214 void
216  double uref2,
217  double t_intensity,
218  double dh,
219  double *rcodcl);
220
221 /*----------------------------------------------------------------------------*/
231 /*----------------------------------------------------------------------------*/
232
233 void
235  double k,
236  double eps,
237  double *rcodcl);
238
239 /*----------------------------------------------------------------------------*/
249 /*----------------------------------------------------------------------------*/
250
251 void
253  double k,
254  double eps,
255  double *rcodcl);
256
257 /*----------------------------------------------------------------------------*/
313 /*----------------------------------------------------------------------------*/
314
315 void
317  cs_real_t p_lg[3][3],
318  cs_real_t alpha[][6]);
319
320 /*----------------------------------------------------------------------------*/
321
323
324 #endif /* __CS_TURBULENCE_BC_H__ */
void cs_turbulence_bc_rij_transform(int is_sym, cs_real_t p_lg[3][3], cs_real_t alpha[][6])
Compute matrix used in the computation of the Reynolds stress tensor boundary conditions.
void cs_turbulence_model_init_bc_ids(void)
Initialize turbulence model boundary condition ids.
Definition: cs_turbulence_bc.c:653
void cs_turbulence_bc_inlet_hyd_diam(cs_lnum_t face_id, double uref2, double dh, double rho, double mu, double *rcodcl)
Definition: cs_turbulence_bc.c:890
double precision, dimension(ncharm), save alpha
Definition: cpincl.f90:99
Definition: cs_defs.h:467
Definition: cs_defs.h:302
void cs_turbulence_bc_inlet_k_eps(cs_lnum_t face_id, double k, double eps, double *rcodcl)
Set inlet boundary condition values for turbulence variables based on given k and epsilon values...
Definition: cs_turbulence_bc.c:946
double precision, dimension(nozppm), save dh
hydraulic diameter
Definition: ppincl.f90:764
void cs_turbulence_bc_inlet_turb_intensity(cs_lnum_t face_id, double uref2, double t_intensity, double dh, double *rcodcl)
Set inlet boundary condition values for turbulence variables based on a diameter , a turbulent intensity and the reference velocity for a circular duct flow with smooth wall.
Definition: cs_turbulence_bc.c:920
void cs_turbulence_bc_ke_turb_intensity(double uref2, double t_intensity, double dh, double *k, double *eps)
Calculation of and from a diameter , a turbulent intensity and the reference velocity for a circu...
Definition: cs_turbulence_bc.c:845
Definition: cs_defs.h:298
void cs_turbulence_model_free_bc_ids(void)
Free memory allocations for turbulence boundary conditions ids.
Definition: cs_turbulence_bc.c:759
Definition: cs_defs.h:468
Definition: cs_field_pointer.h:103
Definition: cs_field_pointer.h:109
void cs_turbulence_bc_set_uninit_inlet_k_eps(cs_lnum_t face_id, double k, double eps, double *rcodcl)
Set inlet boundary condition values for turbulence variables based on given k and epsilon values only...
Definition: cs_turbulence_bc.c:967
Definition: cs_field_pointer.h:71
void cs_turbulence_bc_ke_hyd_diam(double uref2, double dh, double rho, double mu, double *ustar2, double *k, double *eps)
Calculation of , and from a diameter and the reference velocity for a circular duct flow with smo...
Definition: cs_turbulence_bc.c:813
