cs_mesh_builder.h
1 #ifndef __CS_MESH_BUILDER_H__
2 #define __CS_MESH_BUILDER_H__
5  * Auxiliary structure used to read, write, and partition mesh data.
31  * Local headers
34 #include "cs_defs.h"
36 #include "fvm_periodicity.h"
38 #include "cs_base.h"
39 #include "cs_block_dist.h"
40 #include "cs_interface.h"
45
46 /*=============================================================================
47  * Macro definitions
49
51  * Type definitions
53
54 /* Auxiliary and temporary structure used to build or distribute mesh */
55 /* ------------------------------------------------------------------ */
56
57 typedef struct {
58
59  /* Global dimensions */
60
61  cs_gnum_t n_g_faces; /* Number of faces */
62  cs_gnum_t n_g_face_connect_size; /* Size of face connectivity */
63
64  int n_perio; /* Number of periodicities */
65
66  bool have_cell_rank; /* True if cell_rank array is defined */
67
68  /* Temporary mesh data */
69
76
77  /* Periodic features */
78
79  int *periodicity_num; /* Periodicity numbers */
80  cs_lnum_t *n_per_face_couples; /* Nb. face couples per periodicity */
81  cs_gnum_t *n_g_per_face_couples; /* Global nb. couples per periodicity */
82
83  cs_gnum_t **per_face_couples; /* Periodic face couples list. */
84
85  /* Optional partitioning info */
86
87  int *cell_rank; /* Partition id for each cell */
88
89  /* Block ranges for parallel distribution */
90
91  int min_rank_step; /* Minimum block rank step */
92  cs_block_dist_info_t cell_bi; /* Block info for cell data */
93  cs_block_dist_info_t face_bi; /* Block info for face data */
94  cs_block_dist_info_t vertex_bi; /* Block info for vertex data */
95  cs_block_dist_info_t *per_face_bi; /* Block info for parallel face
96  couples */
97
99
100 /*============================================================================
101  * Static global variables
102  *============================================================================*/
103
104 extern cs_mesh_builder_t *cs_glob_mesh_builder; /* Pointer to builder mesh
105  structure */
106
107 /*============================================================================
108  * Public function prototypes
109  *============================================================================*/
110
111 /*----------------------------------------------------------------------------
112  * Create an empty mesh builder structure.
113  *
114  * returns:
115  * A pointer to a mesh builder structure
116  *----------------------------------------------------------------------------*/
117
120
121 /*----------------------------------------------------------------------------*
122  * Destroy a cs_mesh_builder_t structure.
123  *
124  * parameters:
125  * mb <-> pointer to pointer of structure to destroy
126  *----------------------------------------------------------------------------*/
127
128 void
130
131 /*----------------------------------------------------------------------------
132  * Define block distribution sizes for mesh builder.
133  *
134  * parameters:
135  * mb <-> mesh builder
136  * rank_id <-- id of local rank
137  * n_ranks <-- number of associated ranks
138  * min_rank_step <-- minimum rank step between blocks
139  * min_block_size <-- minimum number of entities per block
140  * n_g_cells <-- global number of cells
141  * n_g_faces <-- global number of faces
142  * n_g_vertices <-- global number of vertices
143  *----------------------------------------------------------------------------*/
144
145 void
147  int rank_id,
148  int n_ranks,
149  int min_rank_step,
150  int min_block_size,
151  cs_gnum_t n_g_cells,
152  cs_gnum_t n_g_faces,
153  cs_gnum_t n_g_vertices);
154
155 #if defined(HAVE_MPI)
156
157 /*----------------------------------------------------------------------------
158  * Extract periodic face connectivity information from faces interface
159  * for mesh builder whn running in parallel mode.
160  *
161  * parameters:
162  * n_init_perio <-- number of initial periodicities
163  * mesh <-- pointer to mesh structure
164  * mb <-> pointer to mesh builder structure
165  * periodicity <-- periodicity information
166  * face_gnum <-- global face numbers, or NULL
167  * face_ifs <-- parallel and periodic faces interfaces set
168  *----------------------------------------------------------------------------*/
169
170 void
171 cs_mesh_builder_extract_periodic_faces_g(int n_init_perio,
172  cs_mesh_builder_t *mb,
173  fvm_periodicity_t *periodicity,
174  const cs_gnum_t *face_gnum,
175  const cs_interface_set_t *face_ifs);
176
177 #endif /* defined(HAVE_MPI) */
178
179 /*----------------------------------------------------------------------------*/
180
182
183 #endif /* __CS_MESH_BUILDER_H__ */
bool have_cell_rank
Definition: cs_mesh_builder.h:66
cs_mesh_builder_t * cs_glob_mesh_builder
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:286
cs_block_dist_info_t * per_face_bi
Definition: cs_mesh_builder.h:95
Definition: cs_mesh_builder.h:57
Definition: cs_defs.h:467
int cs_int_t
Fortran-compatible integer.
Definition: cs_defs.h:301
void cs_mesh_builder_destroy(cs_mesh_builder_t **mb)
Definition: cs_mesh_builder.c:195
int min_rank_step
Definition: cs_mesh_builder.h:91
Definition: cs_mesh_builder.h:62
cs_gnum_t ** per_face_couples
Definition: cs_mesh_builder.h:83
cs_gnum_t * face_vertices
Definition: cs_mesh_builder.h:72
cs_int_t * cell_gc_id
Definition: cs_mesh_builder.h:73
cs_gnum_t n_g_faces
Definition: cs_mesh_builder.h:61
Definition: cs_mesh_builder.h:94
cs_int_t * face_gc_id
Definition: cs_mesh_builder.h:74
Definition: cs_mesh_builder.h:93
Definition: cs_defs.h:302
cs_mesh_builder_t * cs_mesh_builder_create(void)
Definition: cs_mesh_builder.c:141
cs_gnum_t * n_g_per_face_couples
Definition: cs_mesh_builder.h:81
int n_perio
Definition: cs_mesh_builder.h:64
cs_lnum_t * n_per_face_couples
Definition: cs_mesh_builder.h:80
int * cell_rank
Definition: cs_mesh_builder.h:87
Definition: cs_interface.h:61
void cs_mesh_builder_define_block_dist(cs_mesh_builder_t *mb, int rank_id, int n_ranks, int min_rank_step, int min_block_size, cs_gnum_t n_g_cells, cs_gnum_t n_g_faces, cs_gnum_t n_g_vertices)
Definition: cs_mesh_builder.c:249
struct _fvm_periodicity_t fvm_periodicity_t
Definition: fvm_periodicity.h:67
Definition: cs_defs.h:298
Definition: cs_mesh_builder.h:92
Definition: cs_defs.h:468
int * periodicity_num
Definition: cs_mesh_builder.h:79
cs_lnum_t * face_vertices_idx
Definition: cs_mesh_builder.h:71
cs_real_t * vertex_coords
Definition: cs_mesh_builder.h:75
cs_gnum_t * face_cells
Definition: cs_mesh_builder.h:70
