| int | cs_interface_rank (const cs_interface_t *itf) |
| | Return process rank associated with an interface's distant elements. More...
| cs_lnum_t | cs_interface_size (const cs_interface_t *itf) |
| | Return number of local and distant elements defining an interface. More...
| const cs_lnum_t * | cs_interface_get_elt_ids (const cs_interface_t *itf) |
| | Return pointer to array of local element ids defining an interface. More...
| const cs_lnum_t * | cs_interface_get_match_ids (const cs_interface_t *itf) |
| | Return pointer to array of matching element ids defining an interface. More...
| cs_lnum_t | cs_interface_get_tr_index_size (const cs_interface_t *itf) |
| | Return size of index of sub-sections for different transformations. More...
| const cs_lnum_t * | cs_interface_get_tr_index (const cs_interface_t *itf) |
| | Return pointer to index of sub-sections for different transformations. More...
| cs_interface_set_t * | cs_interface_set_create (cs_lnum_t n_elts, const cs_lnum_t parent_element_id[], const cs_gnum_t global_number[], const fvm_periodicity_t *periodicity, int n_periodic_lists, const int periodicity_num[], const cs_lnum_t n_periodic_couples[], const cs_gnum_t *const periodic_couples[]) |
| | Creation of a list of interfaces between elements of a same type. More...
| void | cs_interface_set_destroy (cs_interface_set_t **ifs) |
| | Destruction of an interface set. More...
| int | cs_interface_set_size (const cs_interface_set_t *ifs) |
| | Return number of interfaces associated with an interface set. More...
| cs_lnum_t | cs_interface_set_n_elts (const cs_interface_set_t *ifs) |
| | Return total number of elements in interface set. More...
| const cs_interface_t * | cs_interface_set_get (const cs_interface_set_t *ifs, int interface_id) |
| | Return pointer to a given interface in an interface set. More...
| const fvm_periodicity_t * | cs_interface_set_periodicity (const cs_interface_set_t *ifs) |
| | Return pointer to the periocicity structure associated of an interface set. More...
| void | cs_interface_set_renumber (cs_interface_set_t *ifs, const cs_lnum_t old_to_new[]) |
| | Apply renumbering of elements referenced by an interface set. More...
| void | cs_interface_set_add_match_ids (cs_interface_set_t *ifs) |
| | Add matching element id information to an interface set. More...
| void | cs_interface_set_free_match_ids (cs_interface_set_t *ifs) |
| | Free matching element id information of an interface set. More...
| void | cs_interface_set_copy_array (const cs_interface_set_t *ifs, cs_datatype_t datatype, int stride, bool src_on_parent, const void *src, void *dest) |
| | Copy array from distant or matching interface elements to local elements. More...
| void | cs_interface_set_copy_indexed (const cs_interface_set_t *ifs, cs_datatype_t datatype, bool src_on_parent, const cs_lnum_t src_index[], const cs_lnum_t dest_index[], const void *src, void *dest) |
| | Copy indexed array from distant or matching interface elements to local elements. More...
| void | cs_interface_set_sum (const cs_interface_set_t *ifs, cs_lnum_t n_elts, cs_lnum_t stride, bool interlace, cs_datatype_t datatype, void *var) |
| | Update the sum of values for elements associated with an interface set. More...
| void | cs_interface_set_min (const cs_interface_set_t *ifs, cs_lnum_t n_elts, cs_lnum_t stride, bool interlace, cs_datatype_t datatype, void *var) |
| | Update to minimum value for elements associated with an interface set. More...
| void | cs_interface_set_max (const cs_interface_set_t *ifs, cs_lnum_t n_elts, cs_lnum_t stride, bool interlace, cs_datatype_t datatype, void *var) |
| | Update to maximum value for elements associated with an interface set. More...
| void | cs_interface_set_dump (const cs_interface_set_t *ifs) |
| | Dump printout of an interface list. More...
The index is applicable to both local_num and distant_num arrays, with purely parallel equivalences appearing at position 0, and equivalences through periodic transform i at position i+1; In absence of periodicity, it may be NULL, as it is not needed.
- Parameters
| [in] | itf | pointer to interface structure |
- Returns
- pointer to transform index for the interface
The index is applicable to both local_num and distant_num arrays, with purely parallel equivalences appearing at position 0, and equivalences through periodic transform i at position i+1; Its size should thus be equal to 1 + number of periodic transforms + 1, In absence of periodicity, it may be 0, as the index is not needed.
- Parameters
- Returns
- transform index size for the interface
Source and destination arrays define values for all elements in the interface set (i.e. all elements listed by cs_interface_get_elt_ids() when looping over interfaces of a set.
Note that when copying the same type of data to all matching elements, the source and destination index may be the same, if src_on_parent is true. To avoid requiring a separate destination index, the dest_index argument may be set to NULL, in which case it is assumed that source and destination are symmetric, and src_index is sufficient to determine sizes (whether src_on_parent is true or not).
In some use cases, for example when copying values only in one direction, the copying is not symmetric, so both a source and destination buffer must be provided.
- Parameters
| [in] | ifs | pointer to interface set structure |
| [in] | datatype | type of data considered |
| [in] | src_on_parent | true if source array is defined on the elements defined by ifs->elt_ids, false if source array defined directly on cs_interface_set_n_elts(ifs) |
| [in] | src_index | index for source array |
| [in] | dest_index | index for destination array, or NULL |
| [in] | src | source array (size: src_index[cs_interface_set_n_elts(ifs)] or parent array size) |
| [out] | dest | destination array (size: src_index[cs_interface_set_n_elts(ifs)] or dest_index[cs_interface_set_n_elts(ifs)]) |
These interfaces may be used to identify equivalent vertices or faces using domain splitting, as well as periodic elements (on the same or on distant ranks).
Note that periodicity information will be completed and made consistent based on the input, so that if a periodic couple is defined on a given rank, the reverse couple wil be defined, whether it is also defined on the same or a different rank.
In addition, multiple periodicity interfaces will be built automatically if the periodicity structure provides for composed periodicities, so they need not be defined prior to this function being called.
- Parameters
| [in] | n_elts | number of local elements considered (size of parent_element_id[]) |
| [in] | parent_element_id | pointer to list of selected elements local ids (0 to n-1), or NULL if all first n_elts elements are used |
| [in] | global_number | pointer to list of global (i.e. domain splitting independent) element numbers |
| [in] | periodicity | periodicity information (NULL if none) |
| [in] | n_periodic_lists | number of periodic lists (may be local) |
| [in] | periodicity_num | periodicity number (1 to n) associated with each periodic list (primary periodicities only) |
| [in] | n_periodic_couples | number of periodic couples associated with each periodic list |
| [in] | periodic_couples | array indicating periodic couples (interlaced, using global numberings) for each list |
- Returns
- pointer to list of interfaces (possibly NULL in serial mode)
