1 #ifndef __CS_MEASURES_H__ 2 #define __CS_MEASURES_H__ 47 typedef struct _cs_measures_set_t {
72 typedef struct _cs_interpol_grid_t {
171 const int *is_cressman,
172 const int *is_interpol,
198 const int *is_cressman,
199 const int *is_interpol,
cs_lnum_t nb_points
Definition: cs_measures_util.h:76
cs_lnum_t nb_measures_max
Definition: cs_measures_util.h:57
Definition: cs_measures_util.h:72
void mesadd(const cs_int_t *imeset, const cs_int_t *inbmes, const cs_real_t *meset, const cs_real_t *coords, const cs_int_t *cressm, const cs_int_t *interp, const cs_real_t *infrad)
Definition: cs_measures_util.c:1014
Definition: cs_measures_util.h:47
cs_interpol_grid_t * cs_interpol_grid_by_id(int id)
Definition: cs_defs.h:467
int cs_int_t
Fortran-compatible integer.
Definition: cs_defs.h:301
int * is_cressman
Definition: cs_measures_util.h:59
void gripol(const cs_int_t *igrid, const cs_real_t *inval, cs_real_t *pldval)
Definition: cs_measures_util.c:1079
void cs_interpol_field_on_grid(cs_interpol_grid_t *ig, const cs_real_t *values_to_interpol, cs_real_t *interpoled_values)
void mestcr(const char *name, const cs_int_t *lname, const cs_int_t *idim, const cs_int_t *ilved, cs_int_t *imeset)
Definition: cs_measures_util.c:871
int id
Definition: cs_measures_util.h:50
void mestde(void)
Definition: cs_measures_util.c:1101
const char * name
Definition: cs_measures_util.h:74
cs_real_t * coords
Definition: cs_measures_util.h:66
int * rank_connect
Definition: cs_measures_util.h:80
Definition: cs_defs.h:302
int * comp_ids
Definition: cs_measures_util.h:54
cs_interpol_grid_t * cs_interpol_grid_by_name(const char *name)
bool is_connect
Definition: cs_measures_util.h:77
void mesmap(const cs_int_t *imeset, const cs_int_t *inbmes, const cs_real_t *meset, const cs_real_t *coords, const cs_int_t *cressm, const cs_int_t *interp, const cs_real_t *infrad)
Definition: cs_measures_util.c:946
cs_real_t * coords
Definition: cs_measures_util.h:78
void cs_interpol_grid_init(cs_interpol_grid_t *ig, const cs_lnum_t nb_points, const cs_real_t *coords)
void cs_interpol_grids_destroy(void)
integer, save igrid
grid formed by 1D profiles
Definition: atincl.f90:223
const char * name
Definition: cs_measures_util.h:49
cs_measures_set_t * cs_measures_set_by_name(const char *name)
cs_real_t * inf_radius
Definition: cs_measures_util.h:68
bool interleaved
Definition: cs_measures_util.h:58
Definition: cs_measures_util.h:56
void gridcr(const char *name, const cs_int_t *lname, cs_int_t *igrid)
Definition: cs_measures_util.c:910
cs_real_t * measures
Definition: cs_measures_util.h:67
Definition: cs_defs.h:298
void cs_measures_set_add_values(cs_measures_set_t *ms, const cs_lnum_t nb_measures, const int *is_cressman, const int *is_interpol, const cs_real_t *measures_coords, const cs_real_t *measures, const cs_real_t *influence_radius)
void grides(void)
Definition: cs_measures_util.c:1115
void cs_cressman_interpol(cs_measures_set_t *ms, cs_real_t *interpolated_values, int id_type)
void mscrss(const cs_int_t *imeset, const cs_int_t *type, cs_real_t *pldval)
Definition: cs_measures_util.c:1052
void cs_measures_sets_destroy(void)
Definition: cs_defs.h:468
int * is_interpol
Definition: cs_measures_util.h:62
void cs_measures_set_map_values(cs_measures_set_t *ms, const cs_lnum_t nb_measures, const int *is_cressman, const int *is_interpol, const cs_real_t *measures_coords, const cs_real_t *measures, const cs_real_t *influence_radius)
#define CS_PROCF(x, y)
Definition: cs_defs.h:481
cs_measures_set_t * cs_measures_set_create(const char *name, int type_flag, int dim, bool interleaved)
int type
Definition: cs_measures_util.h:51
int dim
Definition: cs_measures_util.h:53
cs_measures_set_t * cs_measures_set_by_id(int id)
int id
Definition: cs_measures_util.h:75
void grimap(const cs_int_t *igrid, const cs_int_t *inpts, const cs_real_t *coords)
Definition: cs_measures_util.c:983
cs_lnum_t * cell_connect
Definition: cs_measures_util.h:79
cs_interpol_grid_t * cs_interpol_grid_create(const char *name)
