| void | cs_lagr_sde (cs_real_t dt_p, const cs_real_t taup[], const cs_real_3_t tlag[], const cs_real_3_t piil[], const cs_real_33_t bx[], cs_real_t tsfext[], const cs_real_3_t gradpr[], const cs_real_33_t gradvf[], cs_real_t terbru[], const cs_real_t vislen[], cs_lnum_t *nresnew) |
| Integration of particle equations of motion: More... | |
| void | cs_lagr_sde_attr (cs_lagr_attribute_t attr, cs_real_t *tcarac, cs_real_t *pip) |
| Integration of a stochastic differential equation (SDE) for a user particle variable (attribute). More... | |
| void cs_lagr_sde | ( | cs_real_t | dt_p, |
| const cs_real_t | taup[], | ||
| const cs_real_3_t | tlag[], | ||
| const cs_real_3_t | piil[], | ||
| const cs_real_33_t | bx[], | ||
| cs_real_t | tsfext[], | ||
| const cs_real_3_t | gradpr[], | ||
| const cs_real_33_t | gradvf[], | ||
| cs_real_t | terbru[], | ||
| const cs_real_t | vislen[], | ||
| cs_lnum_t * | nresnew | ||
| [in] | dt_p | lagrangian time step |
| [in] | taup | dynamic characteristic time |
| [in] | tlag | fluid characteristic time |
| [in] | piil | terme in P-U SDE integration |
| [in] | bx | turbulence characteristics |
| [out] | tsfext | info for return coupling source terms |
| [in] | gradpr | pressure gradient |
| [in] | gradvf | fluid velocity gradient |
| [out] | terbru | FIXME |
| [in] | vislen | FIXME |
| [in] | piil | term in integration of U-P SDEs |
| void cs_lagr_sde_attr | ( | cs_lagr_attribute_t | attr, |
| cs_real_t * | tcarac, | ||
| cs_real_t * | pip | ||
When there is interaction with a boundary face, the integration degenerates to order 1 (even if the 2nd order scheme is active).
| [in] | attr | attribute/variable |
| [in] | tcarac | variable characteristic time pip right-hand side associated with SDE |
| [in] | tcarac | variable characteristic time |
| [in] | pip | right-hand side associated with SDE |
