cs_lagr_event.h
1 #ifndef __CS_LAGR_EVENT_H__
2 #define __CS_LAGR_EVENT_H__
5  * Lagrangian particle event model
31  * Local headers
34 #include "cs_defs.h"
36 #include "cs_lagr_particle.h"
38 #include "assert.h"
45  * Macro definitions
53 #define CS_EVENT_INFLOW (1 << 0)
54
56 #define CS_EVENT_OUTFLOW (1 << 1)
57
59 #define CS_EVENT_REBOUND (1 << 2)
60
62 #define CS_EVENT_DEPOSITION (1 << 3)
63
65 #define CS_EVENT_RESUSPENSION (1 << 4)
66
68 #define CS_EVENT_ROLL_OFF (1 << 5)
69
71 #define CS_EVENT_ROLL_ON (1 << 6)
72
74 #define CS_EVENT_FOULING (1 << 7)
75
76 /*============================================================================
77  * Type definitions
78  *============================================================================*/
79
81 /* ----------------------------- */
82
83 /* Numbering of predefined attributes starts after particle attributes,
84  so that particle attribute can be added to mapped variables traced
85  a particle events */
86
87 typedef enum {
88
96  /* End of event attributes */
97
99
101
103 /* ------------------------------------- */
104
105 typedef struct {
106
107  size_t extents; /* size (in bytes) of event
108  structure */
109  size_t lb; /* size (in bytes) of lower
110  bounds of event data
111  (work area before) */
112
113  size_t size[CS_LAGR_N_E_ATTRIBUTES]; /* size (in bytes) of
114  attributes in event
115  structure for a given
116  time value */
117  cs_datatype_t datatype[CS_LAGR_N_E_ATTRIBUTES]; /* datatype of associated
118  attributes */
119  int count[CS_LAGR_N_E_ATTRIBUTES]; /* number of values for each
120  attribute */
121  ptrdiff_t displ[CS_LAGR_N_E_ATTRIBUTES]; /* displacement (in bytes)
122  of attributes in event
123  data */
124
126
127 /* Event set */
128 /* ------------ */
129
130 typedef struct {
131
132  cs_lnum_t n_events; /* number of events */
134
136  unsigned char *e_buffer;
139
140 /*=============================================================================
141  * Global variables
142  *============================================================================*/
143
144 /*============================================================================
145  * Public function prototypes
146  *============================================================================*/
147
148 /*----------------------------------------------------------------------------*/
155 /*----------------------------------------------------------------------------*/
156
157 void
159
160 /*----------------------------------------------------------------------------*/
164 /*----------------------------------------------------------------------------*/
165
166 void
168
169 /*----------------------------------------------------------------------------*/
175 /*----------------------------------------------------------------------------*/
176
179
180 /*----------------------------------------------------------------------------*/
186 /*----------------------------------------------------------------------------*/
187
188 const char *
190
191 /*----------------------------------------------------------------------------*/
197 /*----------------------------------------------------------------------------*/
198
201
202 /*----------------------------------------------------------------------------*/
208 /*----------------------------------------------------------------------------*/
209
210 void
212
213 /*----------------------------------------------------------------------------*/
231 /*----------------------------------------------------------------------------*/
232
233 void
236  size_t *extents,
237  size_t *size,
238  ptrdiff_t *displ,
239  cs_datatype_t *datatype,
240  int *count);
241
242 /*----------------------------------------------------------------------------*/
250 /*----------------------------------------------------------------------------*/
251
252 void
254
255 /*----------------------------------------------------------------------------*/
265 /*----------------------------------------------------------------------------*/
266
267 inline static void *
269  cs_lnum_t event_id,
271 {
272  assert(event_set->e_am->count[attr] > 0);
273
274  return (unsigned char *)event_set->e_buffer
275  + event_set->e_am->extents*event_id
276  + event_set->e_am->displ[attr];
277 }
278
279 /*----------------------------------------------------------------------------*/
290 /*----------------------------------------------------------------------------*/
291
292 inline static const void *
294  cs_lnum_t event_id,
296 {
297  assert(event_set->e_am->count[attr] > 0);
298
299  return event_set->e_buffer
300  + event_set->e_am->extents*event_id
301  + event_set->e_am->displ[attr];
302 }
303
304 /*----------------------------------------------------------------------------*/
314 /*----------------------------------------------------------------------------*/
315
316 inline static cs_lnum_t
318  cs_lnum_t event_id,
320 {
321  assert(event_set->e_am->count[attr] > 0);
322
323  return *((const cs_lnum_t *)( event_set->e_buffer
324  + event_set->e_am->extents*event_id
325  + event_set->e_am->displ[attr]));
326 }
327
328 /*----------------------------------------------------------------------------*/
337 /*----------------------------------------------------------------------------*/
338
339 inline static void
341  cs_lnum_t event_id,
343  cs_lnum_t value)
344 {
345  assert(event_set->e_am->count[attr] > 0);
346
347  *((cs_lnum_t *)( event_set->e_buffer
348  + event_set->e_am->extents*event_id
349  + event_set->e_am->displ[attr])) = value;
350 }
351
352 /*----------------------------------------------------------------------------*/
362 /*----------------------------------------------------------------------------*/
363
364 inline static cs_real_t
366  cs_lnum_t event_id,
368 {
369  assert(event_set->e_am->count[attr] > 0);
370
371  return *((const cs_real_t *)( event_set->e_buffer
372  + event_set->e_am->extents*event_id
373  + event_set->e_am->displ[attr]));
374 }
375
376 /*----------------------------------------------------------------------------*/
385 /*----------------------------------------------------------------------------*/
386
387 inline static void
389  cs_lnum_t event_id,
391  cs_real_t value)
392 {
393  assert(event_set->e_am->count[attr] > 0);
394
395  *((cs_real_t *)( event_set->e_buffer
396  + event_set->e_am->extents*event_id
397  + event_set->e_am->displ[attr])) = value;
398 }
399
400 /*----------------------------------------------------------------------------
401  * Resize event set buffers if needed.
402  *
403  * \param[in, out] event_set pointer to event set
404  * \param[in] mini mum required
405  *----------------------------------------------------------------------------*/
406
407 void
409  cs_lnum_t min_size);
410
411 /*----------------------------------------------------------------------------*/
417 /*----------------------------------------------------------------------------*/
418
419 void
421
422 /*----------------------------------------------------------------------------
423  * Resize event set buffers if needed.
424  *
425  * \param[in, out] events pointer to event set
426  * \param[in, out] particles pointer to particle set
427  * \param[in] event_id event id
428  * \param[in] particle_id particle id
429  *----------------------------------------------------------------------------*/
430
431 void
433  cs_lagr_particle_set_t *particles,
434  cs_lnum_t event_id,
435  cs_lnum_t particle_id);
436
437 /*----------------------------------------------------------------------------*/
448 /*----------------------------------------------------------------------------*/
449
452
453 /*----------------------------------------------------------------------------*/
454
456
457 #endif /* __CS_LAGR_EVENT_H__ */
Definition: cs_lagr_event.h:130
const char * cs_lagr_event_get_attr_name(cs_lagr_event_attribute_t attr)
Return name associated with a given attribute.
Definition: cs_lagr_event.c:542
cs_datatype_t
Definition: cs_defs.h:260
static void cs_lagr_events_set_lnum(cs_lagr_event_set_t *event_set, cs_lnum_t event_id, cs_lagr_event_attribute_t attr, cs_lnum_t value)
Set attribute value of type cs_lnum_t of a given event in a set.
Definition: cs_lagr_event.h:340
void cs_lagr_event_initialize(void)
Define event map based on defined options.
Definition: cs_lagr_event.c:390
size_t extents
Definition: cs_lagr_event.h:107
Definition: cs_lagr_event.h:87
void cs_lagr_event_set_resize(cs_lagr_event_set_t *event_set, cs_lnum_t min_size)
Definition: cs_lagr_event.c:668
Definition: cs_defs.h:467
Definition: cs_lagr_particle.h:210
void cs_lagr_event_get_attr_info(const cs_lagr_event_set_t *events, cs_lagr_event_attribute_t attr, size_t *extents, size_t *size, ptrdiff_t *displ, cs_datatype_t *datatype, int *count)
Get data extents for a given event attribute.
Definition: cs_lagr_event.c:621
Definition: cs_lagr_event.h:119
void cs_lagr_event_init_from_particle(cs_lagr_event_set_t *events, cs_lagr_particle_set_t *particles, cs_lnum_t event_id, cs_lnum_t particle_id)
Definition: cs_lagr_event.c:721
Definition: cs_defs.h:302
static cs_lnum_t cs_lagr_events_get_lnum(const cs_lagr_event_set_t *event_set, cs_lnum_t event_id, cs_lagr_event_attribute_t attr)
Get attribute value of type cs_lnum_t of a given event in a set.
Definition: cs_lagr_event.h:317
void cs_lagr_event_set_destroy(cs_lagr_event_set_t **events)
Definition: cs_lagr_event.c:589
Definition: cs_lagr_event.h:98
static cs_real_t cs_lagr_events_get_real(const cs_lagr_event_set_t *event_set, cs_lnum_t event_id, cs_lagr_event_attribute_t attr)
Get attribute value of type cs_real_t of a given event in a set.
Definition: cs_lagr_event.h:365
Definition: cs_lagr_event.h:89
static const void * cs_lagr_events_attr_const(const cs_lagr_event_set_t *event_set, cs_lnum_t event_id, cs_lagr_event_attribute_t attr)
Get const pointer to current attribute data of a given event in a set.
Definition: cs_lagr_event.h:293
static void * cs_lagr_events_attr(cs_lagr_event_set_t *event_set, cs_lnum_t event_id, cs_lagr_event_attribute_t attr)
Get pointer to a current attribute of a given event in a set.
Definition: cs_lagr_event.h:268
Definition: cs_lagr_event.h:91
unsigned char * e_buffer
Definition: cs_lagr_event.h:136
cs_lnum_t n_events_max
Definition: cs_lagr_event.h:133
cs_lnum_t n_events
Definition: cs_lagr_event.h:132
const cs_lagr_event_attribute_map_t * cs_lagr_event_get_attr_map(void)
Return const pointer to the main event attribute map structure.
Definition: cs_lagr_event.c:527
const cs_lagr_event_attribute_map_t * e_am
Definition: cs_lagr_event.h:135
Definition: cs_lagr_event.h:94
static void cs_lagr_events_set_real(cs_lagr_event_set_t *event_set, cs_lnum_t event_id, cs_lagr_event_attribute_t attr, cs_real_t value)
Set attribute value of type cs_real_t of a given event in a set.
Definition: cs_lagr_event.h:388
Definition: cs_defs.h:298
Definition: cs_defs.h:468
void cs_lagr_event_set_dump(const cs_lagr_event_set_t *events)
Dump a cs_lagr_event_set_t structure.
Definition: cs_lagr_event.c:692
void cs_lagr_event_finalize(void)
Destroy event set map if it exists.
Definition: cs_lagr_event.c:506
Definition: cs_lagr_event.h:105
Definition: cs_lagr_event.h:121
size_t lb
Definition: cs_lagr_event.h:109
cs_lagr_event_set_t * cs_lagr_event_set_boundary_interaction(void)
Definition: cs_lagr_event.c:769
Definition: cs_lagr_event.h:90
void cs_lagr_event_attr_in_range(int attr)
Check if an event attribute is in a valid range.
Definition: cs_lagr_event.c:652
cs_lagr_event_set_t * cs_lagr_event_set_create(void)
Definition: cs_lagr_event.c:568
Definition: cs_lagr_particle.h:169
