1 #ifndef __CS_ELEC_MODEL_H__ 2 #define __CS_ELEC_MODEL_H__ cs_real_t * xkabel
Definition: cs_elec_model.h:66
const cs_real_t cs_elec_epszer
Definition: cs_elec_model.c:275
int * ibrsec
Definition: cs_elec_model.h:83
int irestrike
Definition: cs_elec_model.h:99
void cs_elec_convert_h_t(int mode, cs_real_t *ym, cs_real_t *enthal, cs_real_t *temp)
Definition: cs_elec_model.c:949
const cs_data_joule_effect_t * cs_glob_transformer
void cs_electrical_model_specific_initialization(cs_real_t *visls0, cs_real_t *diftl0)
Definition: cs_elec_model.c:651
void cs_elec_fields_initialize(const cs_mesh_t *mesh, int isuite)
Definition: cs_elec_model.c:1974
int modrec
Definition: cs_elec_model.h:103
const cs_data_elec_t * cs_glob_elec_properties
cs_real_t * zi
Definition: cs_elec_model.h:87
integer, dimension(nscamx), save isca
Definition: numvar.f90:131
int ntdcla
Definition: cs_elec_model.h:98
void cs_elec_scaling_function(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *dt)
Definition: cs_elec_model.c:2021
void elthht(cs_int_t *mode, cs_real_t *ym, cs_real_t *enthal, cs_real_t *temp)
Definition: cs_elec_model.c:485
int nbelec
Definition: cs_elec_model.h:76
cs_data_joule_effect_t * cs_get_glob_transformer(void)
Definition: cs_elec_model.c:562
Definition: cs_defs.h:467
int cs_int_t
Fortran-compatible integer.
Definition: cs_defs.h:301
void cs_elec_physical_properties(const cs_domain_t *domain)
Definition: cs_elec_model.c:1045
int * ielecc
Definition: cs_elec_model.h:77
cs_real_t * visel
Definition: cs_elec_model.h:64
cs_real_t * zr
Definition: cs_elec_model.h:86
cs_real_t * uroff
Definition: cs_elec_model.h:88
int ngaz
Definition: cs_elec_model.h:57
void ellecd(void)
Definition: cs_elec_model.c:494
cs_real_t elcou
Definition: cs_elec_model.h:110
cs_real_t * rhoel
Definition: cs_elec_model.h:61
cs_real_t * xlabel
Definition: cs_elec_model.h:65
Definition: cs_defs.h:302
int * ibrpr
Definition: cs_elec_model.h:82
cs_real_t * cpel
Definition: cs_elec_model.h:62
integer, save isuite
Indicator of a calculation restart (=1) or not (=0). This value is set automatically by the code; dep...
Definition: optcal.f90:312
cs_real_t * uioff
Definition: cs_elec_model.h:89
cs_real_t srrom
Definition: cs_elec_model.h:111
const cs_elec_option_t * cs_glob_elec_option
int * izreca
Definition: cs_elec_model.h:105
void cs_elec_source_terms(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, int f_id, cs_real_t *smbrs)
Definition: cs_elec_model.c:1662
cs_real_t coejou
Definition: cs_elec_model.h:109
void elini1(cs_real_t *visls0, cs_real_t *diftl0)
Definition: cs_elec_model.c:471
cs_real_t puisim
Definition: cs_elec_model.h:108
int nbtrf
Definition: cs_elec_model.h:80
double precision, dimension(nscamx), save visls0
reference molecular diffusivity related to the scalar J ( ).
Definition: optcal.f90:1185
void eliniv(cs_int_t *isuite)
Definition: cs_elec_model.c:532
void cs_elec_add_property_fields(void)
Definition: cs_elec_model.c:1855
void elreca(cs_real_t *dt)
Definition: cs_elec_model.c:538
double precision, save diftl0
Definition: ppthch.f90:161
void eltssc(const cs_int_t *isca, cs_real_t *smbrs)
Definition: cs_elec_model.c:507
void cs_electrical_model_initialize(void)
Definition: cs_elec_model.c:572
Definition: cs_mesh_quantities.h:90
Definition: cs_domain.h:87
const cs_real_t cs_elec_permvi
Definition: cs_elec_model.c:269
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:315
int * ielecb
Definition: cs_elec_model.h:79
cs_real_t * sigel
Definition: cs_elec_model.h:63
void elphyv(void)
Definition: cs_elec_model.c:501
cs_real_t pot_diff
Definition: cs_elec_model.h:107
option for electric model
Definition: cs_elec_model.h:96
cs_real_t * rnbs
Definition: cs_elec_model.h:85
int npoint
Definition: cs_elec_model.h:58
Definition: cs_defs.h:468
int ntfref
Definition: cs_elec_model.h:81
int ielcor
Definition: cs_elec_model.h:102
#define CS_PROCF(x, y)
Definition: cs_defs.h:481
void cs_electrical_model_finalize(void)
Definition: cs_elec_model.c:614
void eltsvv(const int *f_id, cs_real_t *smbrv)
Definition: cs_elec_model.c:522
cs_real_t * tenspr
Definition: cs_elec_model.h:84
cs_real_t couimp
Definition: cs_elec_model.h:106
physical properties for electric model descriptor.
Definition: cs_elec_model.h:56
void elflux(cs_int_t *iappel)
Definition: cs_elec_model.c:478
void cs_electrical_properties_read(void)
Definition: cs_elec_model.c:757
cs_elec_option_t * cs_get_glob_elec_option(void)
Definition: cs_elec_model.c:552
void cs_elec_add_variable_fields(void)
Definition: cs_elec_model.c:1759
int idreca
Definition: cs_elec_model.h:104
void cs_elec_compute_fields(const cs_mesh_t *mesh, int call_id)
Definition: cs_elec_model.c:1363
int ixkabe
Definition: cs_elec_model.h:97
cs_real_t * th
Definition: cs_elec_model.h:59
cs_real_t * ehgaz
Definition: cs_elec_model.h:60
Structure to read transformer parameters in dp_ELE.
Definition: cs_elec_model.h:75
void cs_elec_source_terms_v(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, int f_id, cs_real_3_t *smbrv)
Definition: cs_elec_model.c:1725
int * ielect
Definition: cs_elec_model.h:78
