Basic examples
Local variables to be added
The following local variables need to be defined for the examples in this section:
integer ifac, iel, ii, ivar
integer izone
integer ilelt, nlelt
double precision uref2, d2s3
double precision rhomoy, xdh, xustar2
double precision xitur
double precision xkent, xeent
integer, allocatable, dimension(:) :: lstelt
double precision, dimension(:), pointer :: boundary_roughness
The following initialization block needs to be added for the following examples:
allocate(lstelt(nfabor)) ! temporary array for boundary faces selection
call field_get_val_s(ibrom, bfpro_rom)
Ad the end of the subroutine, it is recommended to deallocate the work array:
deallocate(lstelt) ! temporary array for boundary faces selection
In theory Fortran 95 deallocates locally-allocated arrays automatically, but deallocating arrays in a symmetric manner to their allocation is good practice, and it avoids using a different logic for C and Fortran.
Body
In the body, we may define several boundary conditions. Here are a few examples.
Inlet example with hydraulic diameter
Assign an inlet to boundary faces of group '2' and x < 0.01.
Warning
the <, <=, >, and >= operators may only be used with variables x, y, and z. This syntax is not a full equation interpreter, so formulas involving x, y, or z are not allowed.
Set a a Dirichlet value on the three components of $ \vect{u} $ on the faces with the selection criterion '2 and x < 0.01' and set a Dirichlet to all the scalars $ \varia $.
Turbulence example computed using equations valid for a pipe.
We will be careful to specify a hydraulic diameter adapted to the current inlet.
We will also be careful if necessary to use a more precise formula for the dynamic viscosity use in the calculation of the Reynolds number (especially if it is variable, it may be useful to take the law from usphyv. Here, we use by default the 'viscl0" value.
Regarding the density, we have access to its value at boundary faces (romb) so this value is the one used here (specifically, it is consistent with the processing in usphyv, in case of variable density).
call getfbr('2 and x < 0.01', nlelt, lstelt)
do ilelt = 1, nlelt
ifac = lstelt(ilelt)
iel = ifabor(ifac)
itypfb(ifac) = ientre
rcodcl(ifac,iu,1) = 1.1d0
rcodcl(ifac,iv,1) = 1.1d0
rcodcl(ifac,iw,1) = 1.1d0
uref2 = rcodcl(ifac,iu,1)**2 &
+ rcodcl(ifac,iv,1)**2 &
+ rcodcl(ifac,iw,1)**2
uref2 = max(uref2,1.d-12)
! Turbulence example computed using equations valid for a pipe.
! We will be careful to specify a hydraulic diameter adapted
! to the current inlet.
! We will also be careful if necessary to use a more precise
! formula for the dynamic viscosity use in the calculation of
! the Reynolds number (especially if it is variable, it may be
! useful to take the law from 'usphyv'. Here, we use by default
! the 'viscl0" value.
! Regarding the density, we have access to its value at boundary
! faces (romb) so this value is the one used here (specifically,
! it is consistent with the processing in 'usphyv', in case of
! variable density)
! Hydraulic diameter: to be defined in the notebook GUI
xdh = notebook_parameter_value_by_name('hydraulic_diam')
! Calculation of turbulent inlet conditions using
! standard laws for a circular pipe
! (their initialization is not needed here but is good practice).
rhomoy = bfpro_rom(ifac)
call turbulence_bc_inlet_hyd_diam(ifac, uref2, xdh, rhomoy, viscl0, &
rcodcl)
! Handle scalars
if (nscal.gt.0) then
do ii = 1, nscal
rcodcl(ifac,isca(ii),1) = 1.d0
enddo
endif
enddo
Inlet example with turbulence intensity
Assign an inlet to boundary faces of group '3'.
Set a a Dirichlet value on the three components of $ \vect{u} $ on the faces with the selection criterion '3' and set a Dirichlet to all the scalars $ \varia $.
Turbulence example computed using turbulence intensity data.
Calculation of $ k $ and $ \varepsilon $ at the inlet (xkent and xeent) using the turbulence intensity and standard laws for a circular pipe (their initialization is not needed here but is good practice)
call getfbr('3', nlelt, lstelt)
do ilelt = 1, nlelt
iel = ifabor(ifac)
! Turbulence example computed using turbulence intensity data.
! Turbulence intensity: to be defined in the notebook GUI
xitur = notebook_parameter_value_by_name('turb_intensity')
! the turbulence intensity and standard laws for a circular pipe
call turbulence_bc_inlet_turb_intensity(ifac, uref2, xitur, xdh, &
rcodcl)
! --- Handle scalars
do ii = 1, nscal
enddo
endif
enddo
Assign an outlet to boundary faces of group 'outlet'
Outlet:
call getfbr('outlet', nlelt, lstelt)
do ilelt = 1, nlelt
! Outlet: zero flux for velocity and temperature, prescribed pressure
! Note that the pressure will be set to P0 at the first
! free outlet face (isolib)
itypfb(ifac) = isolib
enddo
Wall example
Assign a wall to boundary faces of group '5'.
Wall:
call getfbr('5', nlelt, lstelt)
do ilelt = 1, nlelt
! Wall: zero flow (zero flux for pressure)
! friction for velocities (+ turbulent variables)
! zero flux for scalars
itypfb(ifac) = iparoi
! If sliding wall with velocity u = 1:
! rcodcl(ifac, iu, 1) = 1.d0
! If sliding wall with velocity u = 0: nothing to do
! If temperature prescribed to 20 with wall law (scalar ii=1):
ii = 1
icodcl(ifac, isca(ii)) = 5
rcodcl(ifac, isca(ii), 1) = 20.d0
! If temperature prescribed to 50 with no wall law (simple Dirichlet)
! with exchange coefficient 8 (scalar ii=2):
ii = 2
icodcl(ifac, isca(ii)) = 1
rcodcl(ifac, isca(ii),1) = 50.d0
rcodcl(ifac, isca(ii), 2) = 8.d0
! If flux prescribed to 4.d0 (scalar ii=3):
ii = 3
icodcl(ifac, isca(ii)) = 3
rcodcl(ifac, isca(ii), 3) = 4.d0
endif
enddo
Rough wall example
Assign a rough wall to boundary faces of group '7'.
Wall:
call getfbr('7', nlelt, lstelt)
do ilelt = 1, nlelt
! rough friction for velocities (+ turbulent variables)
itypfb(ifac) = iparug
! Roughness for velocity: 1cm
rcodcl(ifac,iu,3) = 0.01d0
! Roughness for scalar (if required): 1cm
rcodcl(ifac,iv,3) = 0.01d0
! If temperature prescribed to 20 (scalar ii=1)
! (with thermal roughness specified in rcodcl(ifac,iv,3)) :
ii = 1
icodcl(ifac, isca(ii)) = 6
ii = 3
endif
enddo
Symmetry example
Assign a symmetry condition to boundary faces of group '4'
call getfbr('4', nlelt, lstelt)
do ilelt = 1, nlelt
! Symmetries
itypfb(ifac) = isymet
enddo
