Atmospheric Imbrication module. This module contains the data structure and subroutines to perform atmospheric imbrication or nesting of a CFD domain within a large scale meteorological field. Starting from a set of large scale meteological profiles (in the format of meteo files) an interpolation is performed for each boundary face both spatially and temporally (using Cressman method) More...
Modules | |
| module | atimbr |
Functions/Subroutines | |
| subroutine | allocate_all () |
| Allocate variables adapted to the number of files and time step to be considered. More... | |
| subroutine | finalize_imbrication () |
| Final step for deallocation. More... | |
| subroutine | interpolate_all_profiles (the_time) |
| Time interpolation of all profiles -. More... | |
| subroutine | dump_interpolated_profiles |
| Print the interpolated profiles for checking purposes. More... | |
| integer function | yo2j (year, ordinal) |
| Converts a (year,ordinal) date to julian calendar date for calculating time shifts. More... | |
| subroutine | read_files_list (a_file, the_list) |
| Reads a file having in each significative line a file name it returns then as 'the_list' the list of lines read a line is significative if it's first char is not / or # or ! The following 3 lines give an example from which one must remove the first two characters. More... | |
| subroutine | find_next_line (unilog, current_line, meteo_file, l_iostat) |
| Find next validated line. More... | |
| subroutine | read_meteo_file (meteo_file) |
| Reads a meteo_file for Code_Saturne Atmospheric Physics option. More... | |
| subroutine | check_chronologies |
| Checks the time variables to ensure the chronology. More... | |
| subroutine | check_positions |
| Check that the profiles position is the same over time. More... | |
| subroutine | check_altitudes |
| Check that the profiles vertical grids heights are strictly increasing. More... | |
| subroutine | hydrostatic_pressure |
| Compute the hydrostastic pressure by Laplace integration. More... | |
| subroutine | potential_temperature_and_density |
| Computes the potential_temperature_and_density profiles. More... | |
| subroutine | get_index (the_array, the_value, lower, upper) |
| Search for the position of a value in an array, assuming that the array is sorted in a strictly increasing order. More... | |
| subroutine | time_interpolation (the_time, the_times, the_profiles, interpolated_profile) |
| Interpolates a "profile" at a given time. Given a series of profiles varying in time you get the profile interpolated from them at the given time. More... | |
| subroutine | altitude_interpolation (the_altitude, the_altitudes, the_profile, interpolated_value) |
| interpolates in a profile at a given altitude More... | |
| subroutine | red_tape |
| Compute radius of influence. More... | |
| subroutine | bounds (string, length, b, e) |
| Identification of the first and last non white character of a string. More... | |
| subroutine | activate_imbrication |
| Prepare data for imbrication by reading meteo files. More... | |
| subroutine | summon_cressman (the_time) |
| Prepare for the cressman interpolation of the variables. More... | |
| logical | imbrication_flag |
| activation flag More... | |
| logical, save | imbrication_verbose |
| logical | cressman_u |
| Flags for activating the cressman interpolation for the boundary conditions. More... | |
| logical | cressman_v |
| logical | cressman_tke |
| logical | cressman_eps |
| logical | cressman_theta |
| logical | cressman_qw |
| logical | cressman_nc |
| double precision | horizontal_influence_radius |
| numerical parameters for the cressman interpolation formulas More... | |
| double precision | vertical_influence_radius |
| integer | line_len |
| Parameter for "meteo" files. More... | |
| character(line_len) | imbrication_files_list |
| character(line_len), dimension(:), allocatable | imbrication_files |
| integer | number_of_files |
| character *(3) | skip_chars |
| integer | thermal_profile_dim |
| Profile dimension variable. More... | |
| integer | dynamical_profile_dim |
| integer | sections_per_file |
| Time sections per files. More... | |
| integer, dimension(:,:), allocatable | years |
| read data from "meteo" files More... | |
| integer, dimension(:,:), allocatable | ordinals |
| integer, dimension(:,:), allocatable | hours |
| integer, dimension(:,:), allocatable | minutes |
| double precision, dimension(:,:), allocatable | seconds |
| double precision, dimension(:,:), allocatable | xpos |
| Positions. More... | |
| double precision, dimension(:,:), allocatable | ypos |
| double precision, dimension(:,:), allocatable | ground_pressure |
| double precision, dimension(:,:,:), allocatable | zt |
| Vertical grid for temperature and humidity variables. More... | |
| double precision, dimension(:,:,:), allocatable | tempc |
| double precision, dimension(:,:,:), allocatable | qw |
| double precision, dimension(:,:,:), allocatable | nc |
| double precision, dimension(:,:,:), allocatable | zd |
| Vertical grid for wind variables. More... | |
| double precision, dimension(:,:,:), allocatable | u |
| double precision, dimension(:,:,:), allocatable | v |
| double precision, dimension(:,:,:), allocatable | tke |
| double precision, dimension(:,:,:), allocatable | eps |
| double precision, dimension(:,:), allocatable, target | times |
| derived data More... | |
| double precision, dimension(:,:,:), allocatable | pressure |
| double precision, dimension(:,:,:), allocatable | theta |
| double precision, dimension(:,:,:), allocatable | density |
| double precision, dimension(:,:), allocatable | ti_zt |
| time interpolated profiles More... | |
| double precision, dimension(:,:), allocatable | ti_tempc |
| double precision, dimension(:,:), allocatable | ti_qw |
| double precision, dimension(:,:), allocatable | ti_nc |
| double precision, dimension(:,:), allocatable | ti_zd |
| double precision, dimension(:,:), allocatable | ti_u |
| double precision, dimension(:,:), allocatable | ti_v |
| double precision, dimension(:,:), allocatable | ti_tke |
| double precision, dimension(:,:), allocatable | ti_eps |
| double precision, dimension(:,:), allocatable | ti_pressure |
| double precision, dimension(:,:), allocatable | ti_theta |
| double precision, dimension(:,:), allocatable | ti_density |
| double precision, dimension(:,:,:), allocatable | coordinates_th |
| additional variables More... | |
| double precision, dimension(:,:,:), allocatable | influence_param_th |
| double precision, dimension(:,:,:), allocatable | coordinates_dyn |
| double precision, dimension(:,:,:), allocatable | influence_param_dyn |
| integer | id_u |
| integer | id_v |
| integer | id_tke |
| integer | id_eps |
| integer | id_theta |
| integer | id_qw |
| integer | id_nc |
| double precision, dimension(:), pointer | times_sequence =>null() |
| 1D array of times at which profiles are given More... | |
This imbrication reads additional meteo files.
