Intel compiler 11.1 produces incorrect optimized code in FVM
Posted: Tue Oct 12, 2010 2:28 pm
A bug in the intel C/C++ compiler (at least version 11.1 on Nehalem architectures) may lead to a crash when writing restart files in parallel, with an error log indicating a segmentation fault under fvm_part_t_block_copy_array.
This bug does not appear when compiled in debug mode, nor does it appear with the Intel compiler on Itanium.
The attached file may be used to replace fvm-0.15.1/src/fvm_part_to_block.c to correct the issue (it simply lowers the optimization level when using the Intel compiler in the affected function).
Compiling FVM with GCC instead of ICC is another possible workaround.
