I need to install qt4 4.3 or higher for Saturne version 2.0.
My system is Red Hat Linux 5.
I really need some help in finding out where I can get qt4 4.3 or higher for Red Hat Linux 5.
Any suggestion/help would be greatly appreciated.
Only because of this, I am not able to install Saturne version 2.0 in my system.
Kindly help.
Thanks and Regards,
Debashis Basu
James McNaughton
Re: qt4 4.3 or higher for Red Hat Linux 5
http://www.riverbankcomputing.co.uk/software/pyqt/download
Debashis Basu
I am looking for qt4 version 4.3 or higher and not pyqt as you have written.
I am just looking for qt4 version 4.3 and higher.
Debashis
Debashis
Google for "qt", and the first hit takes you to http://qt.nokia.com/products/ which is the site you are looking for.
You might even have pre-built binaries for Red Had. Otherwise, you may compile the open-source version from source. Current version is at QT 4.7, and works with Code_Saturne.
But first, check if you have a version of Qt and PyQt as Red Hat rpm packages. Installing Qt manually takes a while but is simple, but installing SIP and PyQt above that is a pain, at least when you do it in a user directory (if you have write access to /usr/local, it is simpler).
Debashis Basu
Based on your suggestion I have gone to the website http://qt.nokia.com/products/ From here, I have gone to the following website
http://qt.nokia.com/downloads
I am going for the LGPL open source license downloads.
Should I download this ?
http://qt.nokia.com/downloads/linux-x11-cpp
Kindly let me know.
Debashis
Kindly let me know.
Debashis
