Problem running a CS2 case
Posted: Fri Jan 07, 2011 7:35 pm
I have just installed code saturne V2 and I tried it with a case of mine working on V1.3.3.
I get this error that I don't understand. Is that a installation problem ? I have added some output file to this message to help.
Thank you
Single processor Code_Saturne simulation
Code_Saturne is running
Working directory (to be periodically cleaned) :
/b1/alexa/tmp_Saturne/TEST_CS2.CAS1.01071628
Kernel version: /usr/local/saturne/cs-2.0-beta2
Preprocessor version: /usr/local/saturne/cs-2.0-beta2
Compilation of user subroutines and linking of Code_Saturne
Preparing calculation
Starting calculation
/b1/alexa/tmp_Saturne/TEST_CS2.CAS1.01071628/localexec: line 3: 25021 Instruction illégale /b1/alexa/tmp_Saturne/TEST_CS2.CAS1.01071628/cs_solver $@
Check Kernel log (listing) and error* files for details
Error in calculation stage.
Thank you
