Problem with Saturne Gui
Hello, I installed the version 2.0.2 of Code_Saturne . Then I created a job by the command " Code_Saturne ....". In the /../../ DATA / I created a new file " name.xml" and tried at the same time changed the font of my GUI. I chose a type, but I do not know which . Suddenly, I lost all the choices of the GUI , the interface attached , and I can not put it as it was before , even if I do a new job, he always n ' there is nothing on the GUI. how I can get my interface? Best regards Nazir.
Re: Problem with Saturne Gui
You can try to remove the file "Code_Saturne GUI.conf" located in $your_home/.config/EDF R&D.
JF
JF
Hello, Thank you very much , it works
Have a nice weekend
Nazir.
Have a nice weekend
Nazir.
