v2.1-rc2 batch systems
Posted: Fri Aug 19, 2011 9:00 pm
by Ashton Neil
I've installed v2.1-rc2 on a couple of clusters and I want to setup the correct settings for the batch system.
I see that the new version differs quite a bit than v2.0.1 in this respect.
From what I understand by exploring the code I should set the batch system in code_saturne.cfg and then i'm presuming the runcase will be modified to include the usual batch options (number of processors, queue etc)?
Unfortunately I'm not sure what the syntax should be in code_saturne.cfg. I keep on getting parsing errors when I try to set it to batch.SGE
Would appreciate any help you can offer (I'm using SGE queues at Manchester University)
Cheers
Neil
Re: v2.1-rc2 batch systems
Posted: Fri Aug 19, 2011 10:56 pm
Hello Neil,
Setting
batch = SGE
should provide the behaviour you expect.
Also, if you have a custom batch template somewhere, setting the absolute path to that template should work (or does since mid-July; I am not sure if your V2.1 pre-release is older than that, but it is a possibility).
Cheers,
