Problem when installing Code Staturne when using "Ubuntu sof
Posted: Tue Feb 14, 2012 3:28 pm
Deal all,
I've just installed UBUNTU 11.10 on a new machine and Ive seen that it was feasable to install Code_Saturne 2.02 thanks to "Ubuntu software center". I've tried this and installation seems to be fine.
I've tried to run a case that I prepared on another machine (and ran succesfully previously) and I noticed that my user routines are not "used" with Code Saturne installed thanks to "Ubuntu software center" even if it is writen that compilation/link is OK (If I run a case that not needs user routines, things are going well). If introducing volontary a bug in my routines, I have a error return from Code_Saturne, which means that the compilation step is not skipped...
Did someone already faced this problem? Have you any suggestions in order to solve it?
Regards.
Julien
Regards.
Julien
