Hello, I have a problem with Saturne 1.3.3. If I try to run a simulation using a mesh with approximately 10,000 or more nodes I get the following error. ERREUR WHILE RUNNING THE KERNEL (SOLVER) and the program stops. However if I take the exact same mesh file and run the simulation using Saturne 2.0 there is no problem. I really have no idea what could be causing this. Any advice would be appreciated.
Kindly let me know.
Debashis Basu
Problem with pre-processor
Re: Problem with pre-processor
The error implies the preprocessor is fine... you probably need to increase the array size, what's the lisiting say?
