Internal coupling in ALE
Posted: Thu Feb 09, 2012 7:47 am
Dear forums
i am trying to work on the internal coupling analysis for a pouch model (Tooth paste dispenser)
the thickness of the pouch is 12mm and if i start the run with the ALE internal coupling approach the displacement obtained for 2000 iterations is just 2.47e-06 (higher stiffness) nothing but 0.0002mm which is very much low.
my main criteria is calculate the time taken to dispense the volume of 13ml from the pouch with a mass flow rate of 0.002 kg/s with deformation
so please help me out
with regards
theja
with regards
theja
