To solve a new equations system , I want to add a new term, which depends on pressure correction (delta P), to the pressure equation (resolp)
The added term is an array called [drhodp (iel)] multiplied by the pressure correction (delta p) gives : drhodp (iel)* (delta p).
My idea is to add directly this term to the matrix diagonal (dam) then after the "matrix" routine is called, so I can write:
do iel = 1 , ncel
dam(iel) = dam(iel) - drhodp(iel)*volume(iel)/dt(iel)
enddo
Is there a better solution to consider this new term ?
Thanks for help.
Rezki
modified pressure equation.
Jacques Fontaine
Re: modified pressure equation.
Could you write your new equations system?
JF
JF
Chebli Rezki
Thanks for answering.
The system is as follows:
* state law to resolve the density and obtain (drho/dp).
* resolve momentum equation (preduv) using the new density.
* resolve the new pressure equation.
Find attached the modified pressure equation.
RC
RC
Jacques Fontaine
Rezki,
I think it is ok. The new term is fully implicit, but I am not sure that linear solvers are able to solve the new system.
Another way is to add the new term in the RHS, and add sweep in the fixed point (and update dp) to implicit it. In this case the matrix is unchanged and the system resolution is not a problem.
JF
JF
Chebli Rezki
Thanks for your help.
Indeed, I already added this term to the RHS inside the loop, it gives :
do 100 isweep = 1, nswmpr
smbr(iel) = - w7(iel) - smbr(iel)
do iel = 1 , ncel
smbr(iel) = smbr(iel) + drhodp(iel)*rtp(iel,ipriph)*volume(iel)/dt(iel)
enddo
100 continue
Do you think I can comment the "dam"'s loop : (do iel = 1 , ncel
dam(iel) = dam(iel) - drhodp(iel)*volume(iel)/dt(iel) enddo) ?
Thanks in advance.
RC
do iel = 1 , ncel
enddo
100 continue
Thanks in advance.
RC
Jacques Fontaine
hello,
You have 2 solutions:
1) add the new term in "dam" and try to solve the new system with linear solvers available in CS (it may be possible)
2) add the new term in RHS, and loop on the system to make it implicit
JF
JF
Chebli Rezki
When trying to solve the previous system , I get divergence Jacobi error :
"Jacobi [Pressure] : divergence après 2542 itérations : résidu initial : 8.3838e-04 ; résidu courant : 1.0069e+02"
Pile d'appels :
1: 0x1aba0a <bft_error+0x3a> (libbft.so.1)
2: 0xecc351 <reslin_+0x1f1> (libsaturne.so.0)
3: 0x10395ed <invers_+0x1ed> (libsaturne.so.0)
4: 0x809d01c <resple_+0x420c> (cs_solver)
5: 0x80879c3 <navsto_+0x34e3> (cs_solver)
6: 0x80a67c6 <tridim_+0x774a> (cs_solver)
7: 0xedff02 <caltri_+0x3df2> (libsaturne.so.0)
8: 0xec24f6 <cs_run+0x846> (libsaturne.so.0)
9: 0xec2855 <main+0x255> (libsaturne.so.0)
10: 0xb5bbd6 <__libc_start_main+0xe6> (libc.so.6)
11: 0x804d231 <> (cs_solver)
Fin de la pile
The linear solver seems to be unable to inverse the pressure matrix.
Just to remind you the equation system :
1- State law , rho = f(P) using the explicit pressure, to resolve the density and obtain (drho/dp).
2- Resolve momentum equation (preduv) using the new density and change the "xnorme" expression :
xnormp(iel) = xnormp(iel) + &
(propce(iel,ipcrom)-romexp(iel))/dt(iel) * volume(iel) &
romexp(iel) : Density at the previous time step.
3 - Resolve the new pressure equation and correct the density (attached file - see above):
3-a : w7(iel) = w7(iel) + ((propce(iel,ipcrom)-romexp(iel))/dt(iel))*volume(iel)
3-b : add (drho/dp) to "dam" then "matrix" routine is called: dam(iel) = dam(iel) - drhodp(iel)*volume(iel)/dt(iel).
or
add this term to "smbr" then "itrgrp" routine is called inside isweep's loop : smbr(iel) = smbr(iel) + drhodp(iel)*rtp(iel,ipriph)*volume(iel)/dt(iel)
3-c : Finally correct the density:
propce (iel,ipcrom) = propce (iel,ipcrom) &
+ drhodp(iel)*(rtp(iel,ipriph)-rtpa(iel,ipriph))
Any suggestions please ?!
RC
Pile d'appels :
Fin de la pile
or
RC
Jacques Fontaine
You can try Conjugate Gradient (CG) solver or Bi-CG solver (iresol = 0 or iresol = 2).
If it still does not work, you must add the new term in the RHS.
JF
JF
