I would like to compute the heat fluxes on some surfaces in my calculation domain. Which routine should I use to do that?
Heat flux calculation
Re: Heat flux calculation
to compute heat fluxes you have to use the routine usproj.f90.
Thanks. I tried to specify the face I want to calculate the heat flux on by using the following lines in usproj.F:
CALL GETFBR('X=0
.and Y<1.1 and Y>0.0 and Z<2.19
.and Z>1.81',NLELT,LSTELT)
However, I get the following error message in listing:
Error parsing expression:
X=0 and Y<1.1 and Y>0.0 and Z<2.19 and Z>1.81
^ Expected operator instead of operand.
Changing < to <= doesn't change anything.
What did I do wrong?
CALL GETFBR('X=0
The X = syntax is not allowed (only inequalities are, as an equality for real numbers is not recommended, so 'x <0.0001 and x > -0.0001' for example should work).
In any case, I prefer the plane[a, b, c, d, epsilon] operator syntax (such that abs(ax+by+cz+d) < epsilon), to the inequality syntax, as the latter can lead the user to believe we have a true equation interpreter, which is not the case, and than be surprised when "x + y < 0" for example doesn't work).
Search for "selection" in the user manual for more examples and the list of all operators.
Thank you for your answer Yvan.
I modified usproj in order to get the flux on one face (see usproj.f at the end of this message).
However, if I use k-omega SST or k-epsilon std with scalable wall function or 2 scale wall function, the calculation keeps running but does not go further than 2 iterations, without giving any error message though(the "derive" value of omega reaches 10^12 after the first iteration though).
Any idea where the problem could come from?
usproj.F:
c BILAN SUR LES PAROIS OPAQUES
c PAROI OPAQUE HAUT
CALL GETFBR('X <=0.0000 and X >=0.00
.and Y <= 2.500 and Y >= 2.250 and Z <= 4.00
.and Z >= 0.00',NLELT,LSTELT)
DO ILELT = 1, NLELT
C
IFAC = LSTELT(ILELT)
C
C --- Element de bord
C
IEL = IFABOR(IFAC)
C
C --- Variables geometriques
C
SURFBN = RA(ISRFBN-1+IFAC)
DISTBR = RA(IDISTB-1+IFAC)
C
C --- Variables physiques
C
VISCT = PROPCE(IEL,IPCVST)
FLUMAB = PROPFB(IFAC,IFLMAB)
C
IF(IPCCP.GT.0) THEN
XCP = PROPCE(IEL,IPCCP)
ELSE
XCP = CP0IPH
ENDIF
C
IF(IPCVSL.GT.0) THEN
XVSL = PROPCE(IEL,IPCVSL)
ELSE
XVSL = VISLS0(ISCAL)
ENDIF
C
C --- Calcul de la contribution au flux sur la facette courante
C (flux de diffusion et de convection, negatif si entrant)
C
XFLUXF = SURFBN * DT(IEL) * XCP *
& (XVSL+VISCT/SIGMAS(ISCAL))/DISTBR *
& (COEFA(IFAC,ICLVAR)+(COEFB(IFAC,ICLVAR)-1.D0)
& *RA(ITRECO+IFAC-1))
& - FLUMAB * DT(IEL) * XCP *
& (COEFA(IFAC,ICLVAR)+ COEFB(IFAC,ICLVAR)
C
XOPAQUEHAUT = XOPAQUEHAUT + XFLUXF
C
ENDDO
C
C - Somme des grandeurs sur tous les processeurs (calculs paralleles)
C
IF (IRANGP.GE.0) THEN
CALL PARSOM (XOPAQUEHAUT)
ENDIF
c Ecriture de la valeur renvoyee
OPEN(unit = 11, file = 'Fluxopaquehaut.hst', status = 'unknown',
& position = 'append') WRITE(11,5600) XOPAQUEHAUT
5600 FORMAT(' ',E14.5)
usproj.F:
c PAROI OPAQUE HAUT
DO ILELT = 1, NLELT
C
C
C
IEL = IFABOR(IFAC)
C
C
C
C
C
IF(IPCCP.GT.0) THEN
ELSE
XCP = CP0IPH
ENDIF
C
ELSE
ENDIF
C
C
C
C
ENDDO
C
C
ENDIF
I would recommend closing the file you use in usproj each time, or keeping it open (using a counter to check if you are running the first pass or not; search for "ipass" in user subroutine examples to see how this may be done).
Otherwise, the crash may be due to a diverging calculation. What is the turbulence model/wall model combination which dos work ? What are the values of y+ you obtain (you may visualize them if you activate post-processing of the boundary mesh) ?
It seems the problem occured only when running the calculation on multiple processors. Anyway, I now used the usproj heat flux calculation routine by only printing the results in the listing file and it works on multiple processors.
I have a question on the results I obtain though. From what I can read in usproj.F, the results obtained are given in Joules. However, I have a surface of 1.8m² in my domain which emits 69.4W/m² (-69.4 set as scalar boundary condition), but the computed value is 8.84, so it's probably not the real heat flux value in W (or J). Any advice on how I could get the heat flux? (the turbulence model I use is k-omega SST with a two-scale wall law).
Axel
Axel
Would anyone have an idea on the problem I'm facing?
