recommended Ubuntu version and mesh file format
Posted: Fri Jul 09, 2010 3:57 pm
Hey all,
Two questions:
1. Linux: I need to install Linux on a machine to test Code_Saturne 2.0rc2. Which version of Ubuntu would you recommend? Also, Is there a clearly better distro than Ubuntu out there, for intended use with EDF open source solutions (Saturne, Aster, ...)?
2-a. Mesh generation: So far we used the gmsh format, which did the job for fairly simple geometries. Now I'm looking into CastNet for a more "industrial" solution (prism layers, abstract modeling). CastNet cannot export Saturne-friendly files yet, but the support is proposing to implement of a patch. They sent me a .neu file to test with Saturne (test_1.2.1.neu in attached zip), but when I perform a mesh check from 2.0rc1, I receive an error message (see error.txt in attached zip). I found on the web another .neu file that I can import without a problem (test_2.4.6.neu in attached zip). Can you tell me what the problem with the 1st file is? (too old version? element types? ...)
2-b. Mesh generation again, but a more general question: Is there a way to avoid using color numbers to identify BCs and volumes in Code_Saturne? Ideally I'd like to name my fluid zones and BC's in a meshing software, and Saturne would detect these at import and make them appear in the GUI. For example, using the attached test_2.4.6.neu file, I could identify named BC's in Paraview. Do I have to type these same names in Saturne? That could be rather painful for complex models.
Thanks!
Jean-Baptiste
Two questions:
Thanks!
Jean-Baptiste
