I have a question concerning the definition of the number of processors. I can use 4
processors and I'm actually using only one. But when I changed the
Nb_Processeurs equal to 4 in the file runcase (or lance in the french version) in the folder SCRIPTS, I
obtained an error line 1248. I think I have to change
other things but I don't know where !!!
I didn't write something in list_processeurs, as I really don't know what to write ......
Thanks for your help.
Gauthier
How to define several processors in the script
gdambrin
- lance.txt
- (47.53 KiB) Downloaded 593 times
Alexandre Douce
Re: How to define several processors in the script
for a standard desktop computer (for a cluster it is different) the only thing you have to change is the variable NOMBRE_DE_PROCESSEURS for example:
NOMBRE_DE_PROCESSEURS=4
For a single processor don't change anything: the variable must be empty. By default, keep the variable LISTE_PROCESSEURS empty to.
If you have an error with parameters, please send us the logs.
gdambrin
I changed the number of processors as you suggested, but I obtain an error. I actually launch my calculations on a global server in a school. I use Exceed to have a distant access and launch a calculation through a Terminal.
I attached the compil.log file as requested.
- resume.txt
- (4.68 KiB) Downloaded 603 times
- listpre.txt
- (6.93 KiB) Downloaded 630 times
- compil.log
- (23.23 KiB) Downloaded 589 times
Alexandre Douce
Re: How to define several processors in the script "runcase" in Code_Saturne v1.3.3
the logs don't show anything wrong: the compilation and linking steps are OK, and the preprocessing step too....
How do you see that your computation fails? Do you have an error and a listing files? What do you see on your terminal?
gdambrin
I have an error appearing in the terminal "ERREUR WHILE RUNNING THE KERNEL (solver)".
I attached the 'erreur' file and 'localexec'.
I have also n0001; n0002; n0003; n0004 files that I can't open which have been created in a folder named "preprocessor output" in the temp file.
I don't have a listing file.
Don't hesitate if you need more informations to give me some help.
Gauthier
Gauthier
- localexec.txt
- (217 Bytes) Downloaded 584 times
- erreur.txt
- (533 Bytes) Downloaded 560 times
It seems the code stops/complains when interpreting the command-line. This usually due to the code not being compiled with MPI support activated.
So you need to check your installation to make sure that Code_Saturne is configured with MPI support, and reinstall otherwise.
gdambrin
Concerning the definition of several processors to do calculation, I have always an error. The MPI support was not installed ! The network manager have installed the MPI support, but I would know if we can check the installation of this support ?
I don't work on a cluster but a server with 8 processors. I have an access with a distant desktop, is that a matter ?
- error.txt
- (41 Bytes) Downloaded 576 times
- erreur.txt
- (533 Bytes) Downloaded 575 times
- compil.log
- (22.99 KiB) Downloaded 557 times
Alexandre Douce
It is the same error as here: https://code-saturne.info/products/code-saturne/forums/general-usage/335742423/646550399
it seems that Code_Saturne is compiled without the support of MPI, even if MPI is installed. In the bin directory of the source you have several macros* files. Open the file that you use depending of you OS, and then you have to complete the variables MPI_HOME, MPI_INC, MPI_LIB.
Perhaps you can see this issue with your administrator.
