Impose Neuman condition pour Temperature.
Philippe Parnaudeau
Post by Philippe Parnaudeau »
The aim of my study is to simulate the flow around one or two hot cylinders.
In a first time, in order to validate my mesh and turbulence model, I decided to impose a Dirichlet condition on the cylinder for the temperature.
Results from this simulation seem to be acceptable, so I decided to simulate the problem with a Newman boundary condition because the only thing I know about the cylinder is the rang of flux deliver (in Watt/m²) [1000, 15 000].
But, result are completely wrong (Temperature are too important, compare with experimental result).
In order to have "better result, I decreased significantly the flux (around 40 W/m²), but I really don't understand what happens.
If anyone has an idea (I'm not an expert in thermal problem, it's my first simulation, so maybe I do something wrong), thanks lot.
Regards.
Mickael Hassanaly
Re: Impose Neuman condition pour Temperature.
Post by Mickael Hassanaly »
Could you post your mesh, set up files, and the results you expect, please? I will check it.
Mickaël
Philippe Parnaudeau
I could give you the gmsh file, and after you can generate the mesh (because the mesh file is too big) with gmsh (2.5).
I think that the field temperature must be compromised between [288-320]° Kelvin.
And when I only imposed -400 W/m², result is [288:575]°K.
setup file : case_ent2_v052_casexh.xml
gmsh file : salle_machine_1_grosse_maille
thanks lot.
salle_machine_1_grosse_maille.txt
gmsh project file
(8.69 KiB) Downloaded 310 times
(6.32 KiB) Downloaded 326 times
Philippe Parnaudeau
I forgot to give you my usphy.F file, which contains Suntherland formulae;
usphyv.F
(23.58 KiB) Downloaded 321 times
Mickael Hassanaly
Thank you. I will check it.
Mickaël
Mickael Hassanaly
Could you check, if you have the following error in your listpre file :
Avertissement
On compte 479136 faces dont un même côté appartient à 2 cellules au moins --> mauvaise connectivité.
I also notice that the boundary color 2000 doesn't exist. You use it for internals faces (faces common to two neighboring cells) so code_saturne can't see it.
Mickaël
Philippe Parnaudeau
I'm don't have this kind of error in my listpre file.
And color 2000 is necessary well define, because it's the inlet boundary condition...
I give you an example of listpre file.
philippe
listpre-09031016.txt
(10.85 KiB) Downloaded 319 times
Mickael Hassanaly
so i may have a problem when i generate your mesh file. Could you send me yours via dl.free.fr?
Thank You
Philippe Parnaudeau
hello,
http://dl.free.fr/vPHM3Aqq7
regards
Mickael Hassanaly
Sorry for the late reply, it takes time because i need to analyse you case in detail.
First thing, you should improve your mesh, the cell size distribution isn't enough homogeneous. I understand that you don't want to have too many cells and that you are interested in thermal phenomena. But in this case, it will generate some problem on gradient computation.
Secondly, you have the inlet and the outlet on the same face. Could you explain me if it's necessary and why? I find that really strange and this is the reason why the mass balance isn't respected. Could you send me one of your listing to verify this point?
Mickaël
