Do you have "error*" or "listing" files in the execution directory ? They should contain more details on the cause of the crash
(you only posted the EnSight case index file, not the mesh or data, so there is very little information, except that the code went at least that far).
Re: Cannot use mesh element
Christophe Rehmet
Hello Yvan and thank you for your answer ,
In fact I managed to find my mistake. It came from the boundary conditions at one of my four injections. However I have another small problem to change the existing code. I try to modifying the code in uslrc.f90 in arc electric module. I defined a cut plane in my geometry and I'd like to use it to measure the current. So I changed the following lines by trying the code given below. I could'nt find the error. Would you have any solution? Thank you.
do ifac = 1, nfac
if( cdgfac(2,ifac).lt. 5d-5 &
.and. cdgfac(2,ifac) .gt. -5d-5 &
.and. surfac(1,ifac) .lt. 1d-8 &
.and. surfac(1,ifac) .gt. -1d-8 &
.and. surfac(3,ifac) .lt. 1d-8 &
.and. surfac(3,ifac) .gt. -1d-8 ) then
iel = ifacel(1,ifac)
elcou = elcou + propce(iel,ipcdc2) * surfac(2,ifac)
endif
enddo
Modified by
call getfac('Plan_courant_3', nlelt, lstelt)
do ilelt = 1, nlelt
ifac = lstelt(ilelt)
do ifac = 1, nfac
enddo
enddo
do ifac = 1, nfac
endif
enddo
Modified by
do ilelt = 1, nlelt
do ifac = 1, nfac
enddo
enddo
You seem to have an extra a loop on ifac :
Should be replaced by :
do ilelt = 1, nlelt
do ifac = 1, nfac
enddo
enddoCode: Select all
do ilelt = 1, nlelt
enddoYvan
Christophe Rehmet
Hello Yvan thank you for your answer but in the sub- routine uslerc.f90 when I introduce (defining and using) lstelt, calculation cannot run. So I try another approach without using lstelt
call getfac('Plan_courant_3', nfac, lndfac)
do ifac = 1, nfac
enddo
With this solution I can measure a current but it blocks on the calculation of POT_VEC1.
do ifac = 1, nfac
enddo
You should use another variable than nfac (for example nlfac), otherwise, calling getfac will change the global nfac value, which probably explains why the calculation blocks.
Also, for correctness, you should replace:
with:
iel = ifacel(1, lndfac(ifac))
and:
surfac(2,ifac)
with:
surfac(2, lndfac(ifac))
with:
and:
surfac(2,ifac)
with:
Christophe Rehmet
Hello Yvan.
I find another solution less problematic than defining a plan. So I used the following code lines to find my plan to -120° relative to the benchmark:
do ifac = 1, nfac
if( - surfac(1,ifac)*1.d0/2.d0 - surfac(2,ifac)*(sqrt(3.d0)/2.d0) .lt. 1d-8 &
. and. - surfac(1,ifac)*1.d0/2.d0 - surfac(2,ifac)*(sqrt(3.d0)/2.d0) .gt. -1d-8 .and. &
cdgfac(1,ifac)*(sqrt(3.d0)/2.d0) - cdgfac(2,ifac)*1.d0/2.d0 .lt. 5d-5 .and. &
cdgfac(1,ifac)*(sqrt(3.d0)/2.d0) - cdgfac(2,ifac)*1.d0/2.d0 .gt. -5d-5 .and. &
surfac(3,ifac) .lt. 1.d-8 &
.and. surfac(3,ifac) .gt. -1.d-8 ) then iel = ifacel(1,ifac)
elcou = elcou + propce(iel,ipcdc1) * surfac(1,ifac) &
+propce(iel,ipcdc2) * surfac(2,ifac)
do ifac = 1, nfac
