Problem in simulations
Debashis Basu
Post by Debashis Basu »
Here is where I currently am and the issues I am working to resolve.  Any advice, correction, or conclusions are welcomed.
Issue 1)
While working with turbulent channel flow problems I found out that the no slip wall condition was not present in my results (ie Velocity at wall was not zero).  This is my current problem which I am trying to resolve.  To investigate I scaled back to a pipe flow problem.  Running the simulation as laminar with a Reynolds number around 100 yields the expected results and velociy profiles for classical pipe flow.  However running the simulation as turbulent, Reynolds number of 30,000 using the K-epsilon turbulence model does not show zero velocity at the walls.  Reading about the K-epsilon turbulence model online I got the impression it may not be the best set of assumptions to use near the wall/boundary layer.  Is this correct? Indeed viewing my results showed the velocity gradent dv/dy near the wall was near infinite.  What turbulence model, might you recommend.
Issue 2)
I am trying to enforce periodic boundary conditions in the stream wise direction.  To do this I THINK? I must proscribe a pressure drop to drive the flow.  To do this I THINK? I must edit the user subroutine ustsns.f90 to change the source term in the momentum equation.  I have never used python before, but it seems pretty straight forward to read and edit the user routine file.  Do you think I am headed in the right direction hear or do you know of a better way to proceed or am I totally wrong.
Issue 3)
Calculation of the Mean Velocity.  To get this from Code Saturne I will have to edit the user subroutine usproj.f90. which is user defined output subroutine.  Am I in the right track ?
I have attached some files as zipped that I thought might help you understanding my problem.
Thanks and Regards,
Debashis
DATA-tar.gz
(433.44 KiB) Downloaded 237 times
James McNaughton
Re: Problem in simulations
Post by James McNaughton »
This may be of interest to you especially regarding the periodicity and pressure drop -
http://cfd.mace.manchester.ac.uk/twiki/ ... leTutorial
James
