1D profile and restart
Maxime Nibart
Post by Maxime Nibart »
I am running cs2rc2 and I can extract 1Dprofiles without any problem while I am not doing a restart calculation.
But for a run that is a restart, Code_Saturne crashes at the iteration  when it is supposed to write something in the 1Dprofiles files.
Has anybody already succeeded in extracting 1D profiles in a restart run ?
Thanks,
Maxime
*** buffer overflow detected ***: /d1/CS_PROJ/tmp_Saturne/GT3D_CAS2.MAILLAGE_ESTET.01101311/cs_solver terminated
[node108:12642] *** Process received signal ***
[node108:12642] Signal: Abandon (6)
[node108:12642] Signal code: (-6)
[node108:12642] [ 0] /lib/libc.so.6(+0x33af0) [0x7ff953d76af0]
[node108:12642] [ 1] /lib/libc.so.6(gsignal+0x35) [0x7ff953d76a75]
[node108:12642] [ 2] /lib/libc.so.6(abort+0x180) [0x7ff953d7a5c0]
[node108:12642] [ 3] /lib/libc.so.6(+0x6d4fb) [0x7ff953db04fb]
[node108:12642] [ 4] /lib/libc.so.6(__fortify_fail+0x37) [0x7ff953e42217]
[node108:12642] [ 5] /lib/libc.so.6(+0xfe0d0) [0x7ff953e410d0]
[node108:12642] [ 6] /lib/libc.so.6(+0xfd539) [0x7ff953e40539]
[node108:12642] [ 7] /lib/libc.so.6(_IO_default_xsputn+0xcc) [0x7ff953db8d1c]
[node108:12642] [ 8] /lib/libc.so.6(_IO_vfprintf+0xf3e) [0x7ff953d892de]
[node108:12642] [ 9] /lib/libc.so.6(__vsprintf_chk+0x99) [0x7ff953e405d9]
[node108:12642] [10] /lib/libc.so.6(__sprintf_chk+0x7f) [0x7ff953e4051f]
[node108:12642] [11] /opt/saturne/cs2rc2/cs-2.0-rc2/lib/libsaturne.so.0(uiprof_+0xbe5) [0x7ff955abaf25]
[node108:12642] [12] /opt/saturne/cs2rc2/cs-2.0-rc2/lib/libsaturne.so.0(caltri_+0x5db4) [0x7ff955a7ea74]
[node108:12642] [13] /opt/saturne/cs2rc2/cs-2.0-rc2/lib/libsaturne.so.0(cs_run+0x843) [0x7ff955a58c23]
[node108:12642] [14] /opt/saturne/cs2rc2/cs-2.0-rc2/lib/libsaturne.so.0(main+0x1f5) [0x7ff955a58f05]
[node108:12642] [15] /lib/libc.so.6(__libc_start_main+0xfd) [0x7ff953d61c4d]
[node108:12642] [16] /d1/CS_PROJ/tmp_Saturne/GT3D_CAS2.MAILLAGE_ESTET.01101311/cs_solver() [0x4020d9]
[node108:12642] *** End of error message ***
Aborted
Mickael Hassanaly
Re: 1D profile and restart
Post by Mickael Hassanaly »
Dear M NIBART,
Could you send me you data set up?
Mickaël Hassanaly
Maxime Nibart
Here are the input files (the mesh file is too big).
I am running 6000 iterations with dt=0.08 and then 15000 more with dt=0.02.
Thanks for your help!
Maxime Nibart
usativ.f90
(13.89 KiB) Downloaded 495 times
run_mesh_ESTET-Copie.xml
(10.9 KiB) Downloaded 554 times
meteogt3d_cas2_cmustd.txt
(7.67 KiB) Downloaded 513 times
Mickael Hassanaly
Dear M NIBART,
Could you post a link where i can download you mesh file? You can use hostfile, megaupload, filefront,... as example.
Mickael Hassanaly
Maxime Nibart
You should be able to download it from here:
http://www.filefront.com/17778904/mesh_from_ESTET3.zip
Mickael Hassanaly
Dear M Nibart,
i wasn't able to get your file because it seems to be corrupted. I make a basic simulation with a restart and 1D profile but i haven't the same problem. Can you post your listing file where you have the error and send again your mesh to the support mail if possible.
Mickaël
