[ask] on parallel computing
salad
Today I encountered a strange phenomenon. I was using a quad core (Intel Q6600) computer to perform simulation, but I only used two cores of it. The calculation was fine. Today I changed to use 3 or 4 cores, found the calculations do not stop for a much longer time than expected. Obviously, there should be problems, but I don't know what they are.
When using 3 cores, the calculation stopped at the first iteration step (I checked listing file)
MAIN CALCULATION
INSTANT 0.100000000E+01 TIME STEP NUMBER 1
--- Phase: 1
Property Min. value Max. value
Density 0.8835E+03 0.8835E+03
LamVisc 0.1277E-01 0.1277E-01
--- Diffusivity:
Scalar Number Min. value Max. value
TempC 1 0.6311E-04 0.6311E-04
** INFORMATION ON BOUNDARY FACES TYPE
Phase : 1
Boundary type Code Nb faces
Inlet 2 50
Smooth wall 5 500
Rough wall 6 0
Symmetry 4 25000
Free outlet 3 50
Undefined 1 0
SIGINT signal (Control+C or equivalent) received.
--> computation interrupted by user.
1: 0x7f69e5899340 ? (?)
2: 0x7f69eb0af05a <opal_progress+0x5a> (libopen-pal.so.0)
3: 0x7f69e64e7995 ? (?)
4: 0x7f69e47d774f ? (?)
5: 0x7f69eb9cbe8c <PMPI_Allreduce+0x17c> (libmpi.so.0)
6: 0x7f69ece23d0f <parcpt_+0x2f> (libsaturne.so.0)
7: 0x7f69ecf1c5f5 <typecl_+0x16e5> (libsaturne.so.0)
8: 0x7f69ecd5a831 <condli_+0x1301> (libsaturne.so.0)
9: 0x7f69ecf013d1 <tridim_+0x6931> (libsaturne.so.0)
10: 0x7f69ecd4a0d5 <caltri_+0x5085> (libsaturne.so.0)
11: 0x7f69ecd254db <cs_run+0x83b> (libsaturne.so.0)
12: 0x7f69ecd257c5 <main+0x1f5> (libsaturne.so.0)
13: 0x7f69e92c6abd <__libc_start_main+0xfd> (libc.so.6)
14: 0x4007a9 ? (?)
When using 4 cores, I even could not arrive at the first step
Directory: /home/salad/tmp_Saturne/duct_2d.MEI.03181539
MPI ranks: 4
I/O mode: MPI-IO, explicit offsets
CALCULATION PREPARATION
Reading file: preprocessor_output
Call stack: 1: 0x7fba619a73c0 ? (?)
2: 0x7fba674e3aad <mca_io_base_component_run_progress+0x3d> (libmpi.so.0)
3: 0x7fba66ba205a <opal_progress+0x5a> (libopen-pal.so.0)
4: 0x7fba674aa5f5 ? (?)
5: 0x7fba602ccdb6 ? (?)
6: 0x7fba674bf1b7 <MPI_Alltoall+0x107> (libmpi.so.0)
7: 0x7fba619aca3b ? (?)
8: 0x7fba619ae41c <ADIOI_GEN_ReadStridedColl+0xb8c> (mca_io_romio.so)
9: 0x7fba619c2712 <MPIOI_File_read_all+0x122> (mca_io_romio.so)
10: 0x7fba619c2977 <mca_io_romio_dist_MPI_File_read_at_all+0x27> (mca_io_romio.so)
11: 0x7fba674dc88f <MPI_File_read_at_all+0xff> (libmpi.so.0)
12: 0x7fba6856ef78 <fvm_file_read_global+0x178> (libfvm.so.0)
13: 0x7fba688a1a40 <cs_io_read_header+0x90> (libsaturne.so.0)
14: 0x7fba68931218 <ledevi_+0x158> (libsaturne.so.0)
15: 0x7fba6897c2a7 <iniini_+0xce3> (libsaturne.so.0)
16: 0x7fba6897effa <initi1_+0x16> (libsaturne.so.0)
17: 0x7fba68817d3e <cs_run+0x9e> (libsaturne.so.0)
18: 0x7fba688187c5 <main+0x1f5> (libsaturne.so.0)
19: 0x7fba64db9abd <__libc_start_main+0xfd> (libc.so.6)
20: 0x4007a9 ? (?)
When using 2 cores, it works very well.
Any advices about this?
Many thanks.
Wayne
http://code-saturne.blogspot.com/
MAIN CALCULATION
--- Phase: 1
--- Diffusivity:
Phase : 1
Inlet 2 50
Smooth wall 5 500
Rough wall 6 0
Symmetry 4 25000
Free outlet 3 50
Undefined 1 0
14: 0x4007a9 ? (?)
MPI ranks: 4
20: 0x4007a9 ? (?)
Many thanks.
Wayne
David Monfort
Re: [ask] on parallel computing
Hello Wayne,
Your problem is quite interesting (sorry...) and quite strange. Someone at EDF encountered the same issue on quad-core laptop: works on 1 or two cores, not with 3 or 4 cores... and unfortunately, I have'nt found a solution yet.
Could you do a couple of tests for me ?
- add an option to the kernel, e.g. set ARG_CS_VERIF variable in the runcase: --mpi-io off
- try with another MPI implementation, e.g. mpich2
Hope you'll find something!
And let me know anyway
salad
Yes, it is interesting :). I remember when I used 1.4.0 or the first beta version of 2.0, I encountered a similar problem that the calculation won't stop if mpi was used. I cannot remember how I dealt with it.
Ok, let's try your suggestions.
For the first suggestion, I add the option to ARG_CS_VERIF; before it is empty.
When I used 4 cores, the calculation didn't stop. I pressed Ctrl-C and obtained:
Parallel Code_Saturne with partitioning in 4 sub-domains
Code_Saturne is running
/home/salad/tmp_Saturne/duct_2d.MEI.03191421
Kernel version: /usr/local
Preprocessor: /usr/local/bin
Preparing calculation
Starting calculation
^C--------------------------------------------------------------------------
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1.
exactly when Open MPI kills them. --------------------------------------------------------------------------
mpirun: killing job...
mpirun noticed that process rank 0 with PID 11518 on node ubuntu exited on signal 2 (Interrupt).
4 total processes killed (some possibly by mpirun during cleanup)
mpirun: clean termination accomplished
Check Kernel log (listing) and error* files for details
Error in calculation stage.
When using 3 cores, the situation is very similar. Both listing files are attached for you.
For mpich2 I need a bit more time since I always used openmpi.
Many thanks!
Regards, Wayne
Many thanks!
Regards, Wayne
- listings.zip
- (15.44 KiB) Downloaded 396 times
David Monfort
For more advanced debugging in parallel, you can activate the logging of the different processus with the option --logp 1 (variable ARG_CS_OUTPUT in the runcase) or in the Advanced Parameters page of the graphical interface. With this option, you will have several "listing" named "listing_nXXXX" -- one for each processus. So, if you hit Control-C, you'll see where each processus hangs.
Another way would be to attach a debugger and go through the stack like this:
cd ~/tmp_Saturne/$STUDY.$CASE.$DATE
ps aux|grep cs_solver (and get the different pid)
gdb cs_solver pid (attach the debugger)
salad
Temporarily the machine was rebooted to Windows to finish some calculations, but the linux environment is still there and definitely I will test what you said later. (Probably one month later, since I'll take a month holiday in April.)
I was thinking whether it is caused by my patched version of Metis. I noticed your statement in SALOME forum, saying there are alternative ways to instead of Metis, and I might try them first.
What do you think?
Wayne
What do you think?
Wayne
David Monfort
Actually, I don't think Metis is the cause of your problem. I tend to think it is due to the MPI implementation, that's why I advised you to try with MPICH2. Nonetheless, if you want to try without Metis, you can disable the partionning stage (in the interface, Batch Running/Advanced Parameters or directly in the runcase script) and then use the solver internal partionning algorithm (Space-Filling Curve, enabled by default in 2.0-rc1).
Let us know if something works in the end, and have a nice holyday
David
David
Jimmy Sapède
got exactly similar problem here with the 2.0 beta2 version of code_saturne running on a bi-quad Xeon under fedora 11.
When i start a parallel calculation with 2 cores only, the calculation performs well but increasing the number of cores used above 3 makes the calculation hangs.
After many tries and many mail exchange with someone at EDF R&D i find that the problem is related to the version of openmpi used (1.4 as far as i remember).
Downgrading OpenMPI to older version (cant remember exactyl but i think it was 1.2.9 or 1.3.x) solves the problem and it runs with my 8 cores.
hope it helps !
hope it helps !
David Monfort
Thanks a lot Jimmy for the feedback !
I hope it will help... though I don't understand why it fails with newer versions of OpenMPI.
David
David
Jimmy Sapède
i reread the mail exchange i had sometiems ago with Yvan Fournier, and the errors making calculation hangs arise from OpenMPI 1.3.3 or 1.3.4 and is solved using 1.2.9 in my case.
When i liste active processes here are the results in case of OpenMPI 1.3.3 (ps -def |grep Saturne) :
jimmy 1371 1332 0 08:24 pts/1 00:00:00
/home/saturne/openmpi-1.3.3/arch/Linux_x86_64/bin/mpiexec -n 4
/home/jimmy/tmp_Saturne/FULL_DOMAIN4.CAS2.11100824/localexec
jimmy 1372 1371 0 08:24 pts/1 00:00:00 /bin/sh
jimmy 1373 1371 0 08:24 pts/1 00:00:00 /bin/sh
jimmy 1374 1371 0 08:24 pts/1 00:00:00 /bin/sh
jimmy 1375 1371 0 08:24 pts/1 00:00:00 /bin/sh
jimmy 1376 1372 97 08:24 pts/1 00:01:12
/home/jimmy/tmp_Saturne/FULL_DOMAIN4.CAS2.11100824/cs_solver --mpi --log
0 --param case2.xml
jimmy 1377 1373 97 08:24 pts/1 00:01:12
0 --param case2.xml
jimmy 1378 1374 97 08:24 pts/1 00:01:12
0 --param case2.xml
jimmy 1379 1375 97 08:24 pts/1 00:01:12
0 --param case2.xml
Got 100% CPU on the 4 threads used, but calcuylation listing hangs and calculation never ends.
using 1.2.9 here are the results of ps -def : (8 threads)
jimmy 9395 2787 0 08:43 pts/1 00:00:00 /bin/sh ./SaturneGUI
jimmy 9396 9395 6 08:43 pts/1 00:00:02 python
/home/saturne/cs-2.0-beta2/arch/Linux_x86_64_dbg/bin/cs gui
jimmy 9415 1 0 08:44 pts/1 00:00:00 /bin/sh
/home/jimmy/Calculs/FULL_DOMAIN3/CAS2/SCRIPTS/runcase
jimmy 9416 1 0 08:44 pts/1 00:00:00 tee
/home/jimmy/Calculs/FULL_DOMAIN3/CAS2/SCRIPTS/batch
jimmy 9445 9415 0 08:44 pts/1 00:00:00
/home/saturne/openmpi-1.2.9/bin/mpiexec -n 8
/home/jimmy/tmp_Saturne/FULL_DOMAIN3.CAS2.11100844/localexec
jimmy 9447 1 0 08:44 ? 00:00:00 orted --bootproxy 1
--name 0.0.1 --num_procs 2 --vpid_start 0 --nodename Workstation
--universe jimmy@Workstation:default-universe-9445
jimmy 9448 9447 0 08:44 ? 00:00:00 /bin/sh
jimmy 9449 9447 0 08:44 ? 00:00:00 /bin/sh
jimmy 9450 9448 66 08:44 ? 00:00:07
/home/jimmy/tmp_Saturne/FULL_DOMAIN3.CAS2.11100844/cs_solver --mpi --log
0 --param case2.xml
jimmy 9451 9447 0 08:44 ? 00:00:00 /bin/sh
jimmy 9452 9449 73 08:44 ? 00:00:08
0 --param case2.xml
jimmy 9453 9447 0 08:44 ? 00:00:00 /bin/sh
jimmy 9454 9447 0 08:44 ? 00:00:00 /bin/sh
jimmy 9455 9451 72 08:44 ? 00:00:08
0 --param case2.xml
jimmy 9456 9453 72 08:44 ? 00:00:08
0 --param case2.xml
jimmy 9457 9447 0 08:44 ? 00:00:00 /bin/sh
jimmy 9458 9447 0 08:44 ? 00:00:00 /bin/sh
jimmy 9459 9454 68 08:44 ? 00:00:08
0 --param case2.xml
jimmy 9460 9457 69 08:44 ? 00:00:08
0 --param case2.xml
jimmy 9461 9458 70 08:44 ? 00:00:08
0 --param case2.xml
jimmy 9462 9447 0 08:44 ? 00:00:00 /bin/sh
jimmy 9463 9462 71 08:44 ? 00:00:08
0 --param case2.xml
Everything works well and calculation ends correctly
0 --param case2.xml
0 --param case2.xml
0 --param case2.xml
0 --param case2.xml
0 --param case2.xml
0 --param case2.xml
0 --param case2.xml
0 --param case2.xml
0 --param case2.xml
0 --param case2.xml
0 --param case2.xml
0 --param case2.xml
David Monfort
Thanks for the feedback.
We are using OpenMPI 1.3.1 on our workstations without known problems. When I have time, I'll try with different versions of OpenMPI to see whether I can reproduce the issue (or not...). I'll let you know if I find something.
