We are having a problem with Saturne. One of my colleagues is trying to use this. We are thinking whether this is a version issue with Saturne.
----------------------------------------------------------------------------------------------------------------------------------------------- His message----------------------------------------This is the exact problem.
When running the preprocessor either through the SaturneGUI or the command line command check_mesh -m "filename" I receive and error message. The following are the exact error messages for each file format I have tired. All of which, according to the manufacturers, is a supported type by Saturne 1.3.3. However each of these file types processes normally on my laptop running Code_Saturne 2.0. Is this is a version issue ?. Any advice, would be appreciated.
1) File type .med (produced in Salome)
Error in ECS execution
ecs_pre.c:411: Fatal error.
File format "MED" support not available in this
installation (file "/home/lee/SATURNE-CODE/run-case/williamson/CYLINDER_TEST/MAILLAGE/cylinder.med").
Call stack
1: 0x2b3a23228cad <bft_error+0x7d> (libbft.so.1)
2: 0x413f05 <ecs_pre__type_format+0x385> (ecs)
3: 0x40e32c <ecs_cmd__lit_arg+0x129c> (ecs)
4: 0x40f6dd <main+0x1bd> (ecs)
5: 0x37b701d994 <__libc_start_main+0xf4> (libc.so.6)
6: 0x408a69 ? (?)
File type .unv (produced in Salome)
ecs_pre_ideas.c:1342: Fatal error.
Error reading line 85582 of file "/home/lee/SATURNE-CODE/run-case/williamson/CYLINDER_TEST/MAILLAGE/cylinder.unv".
Call stack
1: 0x2b1f9c3d6cad <bft_error+0x7d> (libbft.so.1)
2: 0x42d606 ? (?)
3: 0x4306bf <ecs_pre_ideas__lit_maillage+0x7ef> (ecs)
4: 0x40f9ec <main+0x4cc> (ecs)
6: 0x408a69 ? (?)
File type .msh (produced in Ansys or Gambit)
ecs_pre_gmsh.c:416: Fatal error.
Error reading a Gmsh mesh file:
at line 6252 of file "/home/lee/SATURNE-CODE/run-case/williamson/CYLINDER_TEST/MAILLAGE/Ansys_cylinder.msh".
The points definition was not found.
Call stack
1: 0x2b8ff08d2cad <bft_error+0x7d> (libbft.so.1)
2: 0x426469 <ecs_pre_gmsh__lit_maillage+0x15c9> (ecs)
3: 0x40f9ec <main+0x4cc> (ecs)
4: 0x37b701d994 <__libc_start_main+0xf4> (libc.so.6)
5: 0x408a69 ? (?)
Kindly advice. He was trying to simulate flow over a cylinder.
Thanks and Regards,
Debashis
Issues with Preporcessor
Re: Issues with Preporcessor
This is an installation issue: you need to configure/build Code_Saturne with MED file format support for it to be able to read MED files. If a MED library and headers are installed in standard directories (such as when using med and med-dev packages under Debian or Ubuntu), Code_Saturne will support them automatically.
I believe the install script handles MED support also, if it is configured correctly.
If you colleague already uses a SALOME install, there is no need to install MED again: he can point to the MED libraries already included with SALOME (for the Preprocessor's --with-med=<med_root> configure option).
For the other formats, things are stranger, as they do not need additional libraries. Were those files generated under Lnux or Windows ? If they were generated under windows, they should still be readable, but running "dos2unix" if available would be a precaution (especially with the older Code_Saturne 1.3). Otherwise, can you post the output of "head -100 cylinder.unv" for example ?
Another possibility is an install problem. What is the OS and compiler ? If all else fails, could your collegue try a clean reinstall ?
For gambit, you should export in neutral format (.neu file). Try solver -> generic.
