Y+ post-treatment
Pauline Delteil
Y+ post-treatment
Post by Pauline Delteil »
I study a flow inside a pipe and I need to calculate the average of the y+ at the wall, so I wrote the next program :
! Post-traitement du y+
!================Post-traitement du y+ en entree===============================
! localisation du groupe representant l'entree du tube
! nom : "ENTREE"
CALL GETFBR('ENTREE',NLELT,LSTELT)
DO ILELT = 1, NLELT
IFAC = LSTELT(ILELT)
IEL = IFABOR(IFAC)
YPLUS_E = YPLUS_E + RA(IYPLBR+IEL-1)
ENDDO
! si calcul parallele
IF(IRANGP >= 0) THEN
CALL PARSOM(YPLUS_E)
ENDIF
CALL PARCPT(NLELT)
ENDIF
NLELT_E = NLELT
!================Post-traitement du y+ en sortie===============================
! localisation du groupe representant la sortie du tube
! nom : "SORTIE"
CALL GETFBR('SORTIE',NLELT,LSTELT)
DO ILELT = 1, NLELT
IEL = IFABOR(IFAC)
YPLUS_S = YPLUS_S + RA(IYPLBR+IEL-1)
ENDDO
CALL PARSOM(YPLUS_S)
ENDIF
CALL PARCPT(NLELT)
ENDIF
NLELT_S = NLELT
!================Post-traitement du y+ au milieu===============================
! localisation du groupe representant le milieu du tube
! nom : "EXT"
CALL GETFBR('EXT',NLELT,LSTELT)
DO ILELT = 1, NLELT
IEL = IFACEL(2,IFAC)
YPLUS_M = YPLUS_M + RA(IYPLBR+IEL-1)
ENDDO
CALL PARSOM(YPLUS_M)
ENDIF
CALL PARCPT(NLELT)
ENDIF
NLELT_M = NLELT
!===========Calcul de la moyenne de y+ sur le domaine=======================
YPLUS_MOY = (YPLUS_E + YPLUS_S + YPLUS_M)/(NLELT_E + NLELT_S + NLELT_M)
I noticed two surprising things:
1) I use this code on two different configurations, a straight pipe and a curving pipe. In comparison with paraview, I obtain good results for the curving pipe but not for the straight pipe. So does someone know if I have some mistakes in my code.
2) I observe when we see just "YPLUS = RA(IYPLBR+IEL-1)", we obtain some negative and zero values, I don't understand why, have you an idea about the origin of my problem? Furthermore, I would like to know how the y+ is really calculated.
Many thanks,
Pauline
Re: Y+ post-treatment
I think the issue in your code is for example:
DO ILELT = 1, NLELT
  IEL = IFABOR(IFAC)
ENDDO
Where RA(IYPLBR) is defined on boundary faces, not on cells, so
DO IELT= 1, NLELT
  YPLUS_E = YPLUS_E + RA(IYPLBR+IFAC-1)
ENDDO
would seem better (otherwise, you are not adressing the correct memory locations).
You should change the code in all similar cases.
Pauline Delteil
thank you for your answer, it's much better like this.
Best regards, Pauline
