Uninitialized Parameters
Charles Warner
Post by Charles Warner »
I am attempting to help an associate troubleshoot a Code_Saturne case.  He is running 1.3.3.  The program gets through the preporcessor OK, but hangs with the following errors:
==5770== Command: /tmp//tmp_Saturne/RECTANGULAR.CAS1.05251140/cs13.exe -iasize 1000000 -rasize 10000000 -param RECTANGULAR.xml
==5770==
==5770== Conditional jump or move depends on uninitialised value(s)
==5770== at 0x5484CD: stdtcl_ (in /tmp/tmp_Saturne/RECTANGULAR.CAS1.05251140/cs13.exe)
==5770== by 0x4CD3AF: tridim_ (in /tmp/tmp_Saturne/RECTANGULAR.CAS1.05251140/cs13.exe)
==5770== by 0x452CBA: caltri_ (in /tmp/tmp_Saturne/RECTANGULAR.CAS1.05251140/cs13.exe)
I can find nothing in the documentation or here on the forums that tell me what "stdtcl_", "tridim_", and "caltri_" values are, or where they should be initiated.  Can someone point me in the right direction to identify these variables?
Charlie
Re: Uninitialized Parameters
CALTRI , TRIDIM, and STDTCL are Fortran subroutines, built as caltri_, tridim_ and stdtcl_ by the Fortran compiler. Here, Valgrind is telling you that you have a test based on an uniitialzed value in STDTCL, called by CALTRI. To know more, you would need to run the test on a debuig build (for Code_Saturne 1.3, one built with "./lance_install -DBG" instead of "./lance_install"), in which case Valgrind woulf give you the line numbers at which it detects an issue. At this point, when several variables appear on a line, I add print statements of each variable on separate lines just above, run under Valgrind again, and se where it complains.
In any case, STDTCL is used to compute boundary conditions based on data given in the GUI (such as computing a velocity given a flowrate, or computing default turbulence inlet conditions). So you may want to check the boundary condition definitions first.
Charles Warner
Thank you very much.  I suspected an issue with boundary conditions rather than a faulty build, but I have never encountered these particular parameters before.  This is further complicated by the fack that the associate I am trying to help is located in Europe, and I am here in Panama!  You have provided the information I need.
Charlie
