Hi everyone,
My question is about the calculation of the Laplace operator of a scalar or a vector with Code_Saturne. I am driven by the need to construct a dynamical system in Code_Saturne kernel (I'm still working with Code_Saturne v.1.3.3).
Thus, I have to calculate gradients, for which I just use calls to GRDCEL, and Laplacians. For the latter, I cannot use the composition of (INIMAS & DIVMAS ( GRDCEL) ), since this composition of two approximated operators gives erroneous approximations : the continuous definition of the Laplacian = DIV(GRAD( . )) is not true while using this double approximation.
The routine BILSC2.F seems to be more adapted to my need, but I'm not sure to what extent I can use it. I also have to precise that I would use it just at the first time of my calculation.
Did anybody have to calculate Laplacian with Code_Saturne 1.3.3 ? If yes, did you use this routine or another ? The management of the various entries seems to be far from easy for a non time-dependant calculation ...
Any answer would help !
Marie Pomarède
Laplacian calculation
Jonathan Mougenot
Re: Laplacian calculation
I use Code Saturne 2.0.0 and I want to calcute a "laplacian" like :
div(b grad c) where c is a variable and b is a transport property
So I would like to use bilsc2 as you.
I realized a simply steady test case :
-> Geometric : a cube
-> Pressure and velocity without evolution
-> c a variable (without diffusion) equal to z ordonate to the power 3
-> b = 1 everywhere
I computed gradient (grdcel) and laplacian (bilsc2 with iconvp = 0) in usvpst.f90 (source files are in the archive). To define b (viscf and viscb), I used viscfa.
I found difference between analytic expression (respectively 3*z^2 and 6*z) and routines solutions. I resume the difference in comparison.pdf (in the archive). I think that real problems are the boundary cells.
I suppose that I don't use correctly grdcel and bilsc2. Could anybody help me ?
Jonathan
-> b = 1 everywhere
Jonathan
- Test_Case-tar.gz
- (203.73 KiB) Downloaded 290 times
