When i clik on
Eric Belin
When i clik on
Post by Eric Belin »
my config: Red hat 2.6.18-194.el5 64 bits whit Code_saturne 2.01
in virtual machine VMWARE.
When i clik on " check mesh", i have this problem:
| Fin normale du Préprocesseur |
/usr/local/bin/cs_solver: symbol lookup error: /usr/local/lib/libfvm.so.0: undefined symbol: ompi_mpi_info_null
how can i resolv?
Re: When i clik on "check mesh"
What is the path of your MPI (Open MPI) install used with Code_Saturne ? Do you have multiple MPI installs ?
Eric Belin
the path of MPI:
CS_MPI_PATH=/usr/lib/openmpi/1.4-gcc/bin
2 installations of MPI, one with the installer of code_saturne 1.33 and another with code_saturne 2.0.1
Eric
Re: When i clik on
I suspect the MPI library loaded by Code_Saturne 2.0.1 is not the one with which it was compiled. This may happen if you have an LD_LIBRARY_PATH set for Code_Saturne 1.3, or if its version of OpenMPI is in system paths and 2.0's is not.
You should try to
export LD_LIBRARY_PATH=/usr/lib/openmpi/1.4-gcc/lib:$LD_LIBRARY_PATH
in your .profile file to see if it solves the issue.
Eric Belin
Re: When i clik on
no change with:
I see in file RESU/summary.xxxx, no define for   CS_MPI_PATH:   ??
 Kernel          :  /usr/local
    Preprocessor    :  /usr/local/bin
    HOMARD          :
    CS_MPI_PATH     :
    PATH            :  /opt/syrthes3.4.3/bin:/opt/syrthes3.4.3/bin/Linux_x86_64:/opt/aster/public/hdf5-1.6.9/bin:/opt/aster/public/med-2.3.6/bin:/opt/metis-4
.0:/opt/Saturne_1.3.3/Noyau/ncs-1.3.3/bin:/opt/Saturne_1.3.3/Enveloppe/ecs-1.3.3/bin:/opt/syrthes3.4.3/bin:/opt/syrthes3.4.3/bin/Linux_x86_64:/opt/aster/publ
ic/hdf5-1.6.9/bin:/opt/aster/public/med-2.3.6/bin:/opt/metis-4.0:/opt/Saturne_1.3.3/Noyau/ncs-1.3.3/bin:/opt/Saturne_1.3.3/Enveloppe/ecs-1.3.3/bin:/usr/kerbe
ros/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/X11R6/bin:/root/bin
Eric
Do you have the config.log files from the build directories of the FVM library and of the NCS kernel ?
Eric Belin
Re: When i clik on file:///home/yvan/Code_Saturne/Web/old_forums_files/515868552/config_fvm.log
Add in attachment....
Eric
config_fvm.log
(71.23 KiB) Downloaded 313 times
config_ncs.log
(106.21 KiB) Downloaded 322 times
Re: When i clik on
What is the output of:
ldd /usr/local/lib/libfvm.so.0
and of:
nm /usr/local/lib/libfvm.so.0 | grep MPI
and finally:
ls /usr/local/lib/lib*mpi.* /usr/lib/lib*mpi.*
