Radiative transfer module with CS-2.0-rc2
Alicia Consigny
Post by Alicia Consigny »
Hi all,
I recently installed the new version of code saturne 2.0-rc2 on my computer, and I'm having some trouble using the radiative transfer module.
The case I am modelling is the flow and heat transfer in an autoclave. I have flow entering and leaving the autoclave, and grey/black walls with fixed external temperature, for which I know the emissivity, conductivity and thickness. The inlet face has a fixed temperature too. The outlet is free. I have adiabatic walls too. The problem is specified using the GUI and usray1 and usray2.
When running the calculation, I have this kind of error message :
@ @@ ATTENTION : ARRET A L'ENTREE DES DONNEES RAYONNEMENT   @    =========                                               @    XLAMP, EPAP, TEXTP NE DOIVENT PAS ETRE RENSEIGNES       @                                       AVEC ISOTHP = IFREFL
which is weird because there is no reflective wall (IFREFL).
I tried the patch for cs-2.0-rc1 I found on this post Radiative transfers P1-model but it doesn't work.
I tried running the same case with cs-1.4.b without any problem.
I attach here my usray1, usray2 and xml files.
Can you tell me what I should do to solve this problem ?
Thank you very much in advance,
Alicia
usray2.f90
(24.2 KiB) Downloaded 1169 times
usray1.f90
(9.53 KiB) Downloaded 1182 times
100727_autoclave_seul_k-omgSST_rayt.xml
(12.6 KiB) Downloaded 1136 times
