problem k-omega sst
eka
problem k-omega sst
Post by eka »
I work with code_saturne 2.1.4.
I use unsteady flow simulation with k-omega,
when running, I have the following error in the listing :
1: 0x7f83834b79e0 <+0x329e0> (libc.so.6)
2: 0x7f83840f6353 <+0x146353> (libsvml.so)
3: 0x581200 <> (cs_solver)
4: 0x4a7c51 <> (cs_solver)
5: 0x426b78 <> (cs_solver)
6: 0x422663 <> (cs_solver)
7: 0x7f83834a3bc6 <__libc_start_main+0xe6> (libc.so.6)
8: 0x420839 <> (cs_solver)
Could anyone tell me what should i do?
Best Regards,
Eka
listing.txt
(34.73 KiB) Downloaded 647 times
Re: problem k-omega sst
In your execution directory, could you run "addr2line --exe cs_solver 0x581200" and post the result ?
(0x581200 is the last address that appears in the backtrace in your "listing" file; testing with the values below can also help).
This should tell you the name of the source file in which the problem occurred, so it may help finding the cause.
eka
Post by eka »
I have run ""addr2line --exe cs_solver 0x581200"
and the answer is : ??:0
Then i tried to use code_saturne version 1.3.3, it works.
Eka
You might have some other error in the setup for version 2.1.
Did you try addr2line for the other addresses in the backtrace (from top to
bottom) ?
eka
Post by eka »
I have tried to run all of the data and get the same results.
Thank you.
Best Regards,
Eka
eliberge
Post by eliberge »
the same problem appears using LES turbulence model.
I am working on the same mesh file than Eka, and the end of the listing file is :
Signal SIGFPE (exception en virgule flottante) intercepté !
Pile d'appels :
1: 0x7fd8bc5da9e0 <+0x329e0> (libc.so.6)
2: 0x7fd8bdae423c <+0x12c23c> (libsvml.so)
3: 0x7fd8bdae41c3 <+0x12c1c3> (libsvml.so)
4: 0x59bb9e <> (cs_solver)
5: 0x4a88fc <> (cs_solver)
6: 0x425738 <> (cs_solver)
7: 0x421223 <> (cs_solver)
8: 0x7fd8bc5c6bc6 <__libc_start_main+0xe6> (libc.so.6)
9: 0x4208f9 <> (cs_solver)
Fin de la pile
and the answer of the command :
addr2line --exe /Calcul/Apps2/saturne4.2.4/v217/libexec/code_saturne/cs_solver 0x4208f9
is :
/usr/src/packages/BUILD/glibc-2.11.1/csu/../sysdeps/x86_64/elf/start.S:116
Erwan
Could you try addr2line on other addresses from the backtrace (especially 0x59bb9e) ?
eliberge
Post by eliberge »
Thank you for your help.
Please find the results of the addr2line command :
>addr2line --exe /lib64/libc.so.6 0x7ff0f7189bc6
??:0
>>addr2line --exe /Calcul/Apps2/saturne4.2.4/v217/libexec/code_saturne/cs_solver 0x421223
??:0
>addr2line --exe /Calcul/Apps2/saturne4.2.4/v217/libexec/code_saturne/cs_solver 0x425738
??:0
>addr2line --exe /Calcul/Apps2/saturne4.2.4/v217/libexec/code_saturne/cs_solver 0x4a88fc
??:0
>addr2line --exe /Calcul/Apps2/saturne4.2.4/v217/libexec/code_saturne/cs_solver 0x59bb9e
??:0
>addr2line --exe /Calcul/Apps/intel/lib/intel64/libsvml.so 0x7ff0f86a71c3
??:0
>addr2line --exe /Calcul/Apps/intel/lib/intel64/libsvml.so 0x7ff0f86a723c
??:0
>addr2line --exe /lib/libc.so.6 0x7ff0f719d9e0
??:0
Erwan
The addr2line information is less useful than I hoped. Using a version of the code compiled in debug mode (see installtion manual), it would be more useful.
I would suggest trying version 2.2.1 to see if you have the same problem, but this means upgrading your data setup.
I could also test your case if you post it here, but I probably won't have the time to do this before a few weeks.
eliberge
Post by eliberge »
Thank you.
I will try the 2.2.1 version.
Erwan
