cs_user_radiative_transfer_bcs function upgrade
AdamLarat
Post by AdamLarat »
I am starting a new project using Code_Saturne and I first wish to upgrade for v7.1 to v8.0.
Unfortunately, I have a user defined function cs_user_radiative_transfer_bcs which used to have the following signature :
void cs_user_radiative_transfer_bcs	(	int 	nvar,
const int 	bc_type[],
int 	icodcl[],
int 	isothp[],
cs_real_t * 	tmin,
cs_real_t * 	tmax,
cs_real_t * 	tx,
const cs_real_t 	dt[],
cs_real_t 	rcodcl[],
const cs_real_t 	thwall[],
const cs_real_t 	qincid[],
cs_real_t 	hfcnvp[],
cs_real_t 	flcnvp[],
cs_real_t 	xlamp[],
cs_real_t 	epap[],
cs_real_t 	epsp[],
cs_real_t 	textp[]
when the new expected signature is now
void cs_user_radiative_transfer_bcs	(	cs_domain_t * 	domain,
int 	isothp[],
cs_real_t * 	tmin,
cs_real_t * 	tmax,
cs_real_t * 	tx,
cs_real_t 	hfcnvp[],
cs_real_t 	flcnvp[],
cs_real_t 	xlamp[],
cs_real_t 	epap[],
cs_real_t 	epsp[],
cs_real_t 	textp[]
The code I am running is using the nvar integer parameter and is filling up the rcodcl output vector of the v7.1. Both have disappeared in the v8.0 signature.
Could someone help me translating my user defined function to Code_Saturne_v8.0 ?
Thanks a lot!
Re: cs_user_radiative_transfer_bcs function upgrade
You can compare examples in v8.0 (https://github.com/code-saturne/code_sa ... sfer_bcs.c) and v7.0 (https://github.com/code-saturne/code_sa ... sfer_bcs.c) to see how you can adapt the code.
With the v8.0 approach, you will not need nvar anymore.
AdamLarat
Post by AdamLarat »
Thanks Yvan, it worked as a charm! :thumb:
