mesh helix surface
Posted: Fri Apr 25, 2025 9:45 am
by dimitri14
Hello, i've got an error running flow simulation around an immersed monolith. i have run this simulation with a smooth monolith and it's working, but with the helix one it doesn't work.
I was thinking it was cause of the helix shape of the mesh but the preprocesor.log file is Ok
Have you an idea about the error ?
Files are accessible at https://unicloud.unicaen.fr/index.php/s/reY7iWqK7LdbSRE
Re: mesh helix surface
Posted: Thu May 01, 2025 11:19 am
This is certainly a mesh quality issue, even though the classical quality "bad cell indicators" seem mostly OK. The fact that computing the wall distance needs disabling the reconstruction (see log) is a giveaway. Some cells might be too "flat" near the boundary.
Extruding the mesh at inlets/outlets and inserting a boundary cell layer (see mesh modification examples in documentation) might help a bit). If you can do that upstream with the meshing tool it is even better.
Posted: Sun May 04, 2025 3:48 pm
by dimitri14
Thank you Yvan for your answer
I'll work on the mesh this week and keep you inform
