Problem with HTLES Hybrid Model
finzeo
Post by finzeo »
Good morning,
I have been trying to test the HTLES hybrid model using version v8.0.1. In the user routines cs_user_parameters.c and cs_user_initialization.c, I use the following instructions:
cs_turb_model_t *turb_model = cs_get_glob_turb_model();
turb_model->iturb = CS_TURB_K_OMEGA;
turb_model->type = CS_TURB_HYBRID;
turb_model->hybrid_turb = CS_HYBRID_HTLES;
However, I am encountering the following errors:
SIGABRT signal (abort) intercepted.
   1: 0x7f6de099eacf <gsignal+0x10f>                  (libc.so.6)
   2: 0x7f6de0971ea5 <abort+0x127>                    (libc.so.6)
   3: 0x7f6de09dfcd7 <+0x8fcd7>                       (libc.so.6)
   4: 0x7f6de09e6fdc <+0x96fdc>                       (libc.so.6)
   5: 0x7f6de09e73fc <+0x973fc>                       (libc.so.6)
   6: 0x7f6de2c4def0 <bft_mem_free+0x260>             (libsaturne-8.0.so)
   7: 0x7f6de2a4705a <cs_htles_initialization+0xeca>  (libsaturne-8.0.so)
   8: 0x7f6de23f6024 <caltri_+0x1455>                 (libsaturne-8.0.so)
   9: 0x7f6de38b9360 <main+0x760>                     (libcs_solver-8.0.so)
  10: 0x7f6de098ad85 <__libc_start_main+0xe5>         (libc.so.6)
  11: 0x40624e     <_start+0x2e>                    (cs_solver)
At the end of the listing, I see this error:
** VARIABLES INITIALIZATION
 Property           Min. value  Max. value
  density           0.1206E+01  0.1206E+01
  molecular_viscos  0.1758E-04  0.1758E-04
  turbulent_viscos  0.2193E-07    Infinity
HTLES: Error counter: 24
Tracing the source code, I found this in cs_turbulence_htles.c:
/* Verification
 * TODO correct it in parallel
for (cs_lnum_t c_id = 0; c_id < n_cells; c_id++) {
  if (cpt_edg_per_cells[c_id] != 36) {
    bft_printf("HTLES: Error counter: %d \n", cpt_edg_per_cells[c_id]);
My question is:
Is the HTLES code designed to work only with purely hexahedral meshes?
Re: Problem with HTLES Hybrid Model
I just talked with the colleague who implemented the model, and the short answer is "yes". Apparently, tha model needs both an estimation of the cell span (which can be approximated using a cubic root of the volume), and a stricter test of the longest span, for near wall cells with higher aspect ratio.
So this quantity could probably be estimated in a better manner, not restricted to hexahedra, but you would need to change the test. I would not expect the model to work well on a purely tetrahedral mesh, but changing or removing this test might be interesting with a hex-dominant (or perhaps polyhedral ?) mesh with only a few non hexahedral cells.
finzeo
Post by finzeo »
Thank you for your response.
If I understand correctly, the restriction exists solely to enable the straightforward calculation of the dlt_max array in cs_turbulence_htles.c?. If your answer is yes, I was thinking of implementing a loop over the cells, accessing the neighboring cell centers for each cell, and thus computing any minimum or maximum distance between cell centers.
In fact, I have already done something similar in the DDES model to compute the xdelta variable by modifying the source files. I presented this to Jean-François, as it yielded better results in agreement with some published papers.
Do you think this would be sufficient to remove the restriction and make it work for any mesh without generating errors?
I'll try to remember to check with Jean-François to confirm, but yes, I think you cluld try the same sort of approach here.
