MPI fail on multiprocess run
fracenvi
Post by fracenvi »
I'm trying to run a case on a multiprocess setup, but whatever the amount of processors i provide it always gives me back:
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
I built that versione of the code with:
./code_saturne/configure --prefix=/home/cenvinzf@coria.fr/cs_openmpi --with-hdf5=/home/cenvinzf@coria.fr/Desktop/CS_4COUPLING/CS_LIB/hdf5/install_mpi --with-med=/home/cenvinzf@coria.fr/Desktop/CS_4COUPLING/CS_LIB/med/install_mpi --with-mpi=/home/cenvinzf@coria.fr/Desktop/OpenMPI --enable-mpi --enable-debug CC=/home/cenvinzf@coria.fr/Desktop/OpenMPI/bin/mpicc CXX=/home/cenvinzf@coria.fr/Desktop/OpenMPI/bin/mpicxx FC=/home/cenvinzf@coria.fr/Desktop/OpenMPI/bin/mpif90
And i made sure the MPI paths are always visible through the .bashrc file. Where might be the problem then?
Thanks to anyone who can help,
Francesco
StandardRANSUser001
Re: MPI fail on multiprocess run
Post by StandardRANSUser001 »
Hi Francesco,
Sometimes I find it handy to run the install_saturne.py script, and then if something crashes, copy the configure command that is generated in this script. I am unsure whether I needed the CXX and FC commands were needed in my install. I have found that it is also important to get the order of the packages correct (The script handles this).
Sean Hanrahan
Don't forget the usual troubleshooting recommendations, as described in the BPG's (https://www.code-saturne.org/documentat ... oting.html).
What do the run_solver.log or error* files say ?
fracenvi
Post by fracenvi »
I actually managed to sort the bug out, as the command i was using to launch the code was not passing the correct number of processors needed to perform the computation.
Francesco
