Hi Everyone,
I would like to set up a case for a compressible flow without the GUI, and I am finding it tricky to get this working.
I suspect that there may be an incompatibility between the compressible Fortran modules (uscfx1, uscfx2) and the cs_user_parameters.c files. Has anybody else had issues navigating this? Perhaps I have missed something in the documentation?
As some reference, I have undertaken the following work:
1. I have been able to run the compressible case, when developed in the GUI (KW SST or SSG-epsilon)
2. I have been able to rebuild the same case (incompressible) without the GUI (KW SST)
3. I am unable to build a compressible case without the GUI - I have built this with the example files provided in the 8.0.3 release.
Looking at version 8.2 log (https://github.com/code-saturne/code_sa ... er/NEWS.md), I can see that the compressible module has been migrated to cs_user_parameters.c. Does this suggest that it may be easier to work with the compressible model in CS V8.2?
I am hoping that somebody could provide a minimal working example of a compressible case, built entirely without the GUI. This can be either in V8.0 or 8.2.
Any assistance with this would be greatly appreciated.
Sean Hanrahan
Running the Compressible Module without GUI
