Dear Code_Saturne users,
Using Code_Saturne for atmospheric flows, I have some difficulties in order to maintain input meteo profiles (initially generated through idealized large scale meteorological data) on a flat terrain with stable conditions (it's quite fine for both neutral and unstable conditions). Any feedback/suggestion on this?
I'd like to make some tests by changing IWALFS (in order to test CS_WALL_F_S_MONIN_OBUKHOV while default is CS_WALL_F_S_MONIN_LOUIS), could someone tell me where this can be done since this parameter does not seem to be accessible in the GUI?
Kind regards
Julien C.
Atmospheric flow : Changing IWALFS
Re: Atmospheric flow : Changing IWALFS
It does not appear in the documentation, but if you search for MONIN_OBUKHOV in the src/user_examples/cs_user_parameters-base.c file, you will find an example.
Julien.Commanay
Thanks a lot!
Hi Julien,Using Code_Saturne for atmospheric flows, I have some difficulties in order to maintain input meteo profiles (initially generated through idealized large scale meteorological data) on a flat terrain with stable conditions (it's quite fine for both neutral and unstable conditions). Any feedback/suggestion on this?
Stable meteo-conditions is harder to simulate. But you can try to turn on Boussinesq approximation and maybe decrease a bit solver precision on "pressure"
Konstantin
Julien.Commanay
Thanks Konstantin
