HTTP Error 403 when running second pass of install_saturne.py
Posted: Thu Nov 23, 2023 3:31 pm
Hello, I'm trying to install Code_Saturne v7.0.4 on a new machine and I'm running into a HTTP Error 403 (I attached the console log below) when running the install_saturne.py script the second time. Not sure what is causing this, I have successfully installed Code_Saturne on another computer before without running into this problem. Any help would be appreciated!
This is my setup file:
Installation of Code_Saturne
____________________________
The process will take several minutes.
You can have a look at the log file meanwhile.
Check the setup file and some utilities presence.
o Checking for cc... /usr/bin/cc
o Checking for mpicc... /usr/bin/mpicc
o Checking for f95... /usr/bin/f95
o Checking for python3... /opt/hpds/miniconda/bin/python3
Python version is 3.9
o Checking for make... /usr/bin/make
Download of HDF5
(https://support.hdfgroup.org/ftp/HDF5/releases/hdf5-1.10/hdf5-1.10.6/src/hdf5-1.10.6.tar.gz)
Download of CGNS
(https://github.com/CGNS/CGNS/archive/v4.1.2.tar.gz)
Download of MED
(http://files.salome-platform.org/Salome/other/med-4.1.0.tar.gz)
File "/mnt/d/code_saturne/saturne_build/../code_saturne-7.0.4/install_saturne.py", line 1354, in <module>
setup.install()
File "/mnt/d/code_saturne/saturne_build/../code_saturne-7.0.4/install_saturne.py", line 1092, in install
p.download()
File "/mnt/d/code_saturne/saturne_build/../code_saturne-7.0.4/install_saturne.py", line 246, in download
urllib.request.urlretrieve(self.url, self.archive)
File "/opt/hpds/miniconda/lib/python3.9/urllib/request.py", line 239, in urlretrieve
with contextlib.closing(urlopen(url, data)) as fp:
File "/opt/hpds/miniconda/lib/python3.9/urllib/request.py", line 214, in urlopen
return opener.open(url, data, timeout)
File "/opt/hpds/miniconda/lib/python3.9/urllib/request.py", line 523, in open
response = meth(req, response)
File "/opt/hpds/miniconda/lib/python3.9/urllib/request.py", line 632, in http_response
response = self.parent.error(
File "/opt/hpds/miniconda/lib/python3.9/urllib/request.py", line 561, in error
return self._call_chain(*args)
File "/opt/hpds/miniconda/lib/python3.9/urllib/request.py", line 494, in _call_chain
result = func(*args)
File "/opt/hpds/miniconda/lib/python3.9/urllib/request.py", line 641, in http_error_default
raise HTTPError(req.full_url, code, msg, hdrs, fp)
urllib.error.HTTPError: HTTP Error 403: ForbiddenCode: Select all
# Setup file for Code_Saturne installation
# Download packages ?
download yes
# Install Code_Saturne with debugging symbols
debug no
# Installation directory
prefix /home/bryan/Code_Saturne/7.0.4
# Optional architecture Name (installation subdirectory)
use_arch no
arch Linux_x86_64
# C compiler and optional MPI wrapper
compC /usr/bin/cc
mpiCompC /usr/bin/mpicc
# Fortran compiler
compF /usr/bin/f95
# C++ compiler and MPI wrapper for optional packages
# Required only for static builds using the MED library
# or for build of optional modules such as MEDCoupling
# support.
compCxx /usr/bin/c++
mpiCompCxx /usr/bin/mpicxx
# Python interpreter.
python /opt/hpds/miniconda/bin/python3
# Disable the Graphical user Interface ?
disable_gui no
# Disable frontend (also disables GUI) ?
# May be useful for debug builds and HPC cluster builds
# installed side-by side with a full build.
disable_frontend no
# Optional SALOME platform install path.
# This is the path for the main SALOME directory,
# not the application directory.
# If Code_Saturne is built with SALOME support,
# running "code_saturne salome" will launch the
# associated application, containing the CFDSTUDY module.
salome no
# Optional packages:
# MED / HDF5 For MED file format support
# (used by SALOME and by Gmsh)
# CGNS / HDF5 For CGNS file support
# (used by many meshing tools)
# Scotch (includes PT-Scotch) and/or ParMetis
# for parallel partitioning
# For Linux workstations, HDF5, CGNS, and even MED
# packages may be available through the package manager.
# HDF5 is also often available on large systems.
# When building with SALOME, the platform distribution's
# packages may be used, by setting in the matching entry
# 'yes' under the "Use" column and simply 'salome' under
# the path column.
# Scotch and Pt-Scotch are available in some Linux
# distributions, but may be built with options
# incompatible with non-threaded Code_Saturne runs.
# To install CGNS or ParMetis, the CMake
# configuration/installation tool is required
# (it is available in most Linux distributions).
# Name Use Install Path
hdf5 yes yes None
cgns yes yes None
med yes yes None
scotch no no None
parmetis no no None
