prescribing k and omega user profiles at inlet
daniele
Post by daniele »
I simple question, can I use:
call getfbr('INLET', nlelt, lstelt)
do ilelt = 1, nlelt
  ifac = lstelt(ilelt)
  rcodcl(ifac,iu,1) = 0.5d0
  rcodcl(ifac,iv,1) = 0.d0
  rcodcl(ifac,iw,1) = 0.d0
  rcodcl(ifac,ik,1) = 0.5d0
  rcodcl(ifac,iomg,1) = 10000.d0
enddo
(values prescribed just as an example) inside cs_user_boundary.f90 to impose the desired profiles of k and omega at inlet?
When I do that, the code seems to ignore the subroutine and takes the values specified in the GUI (I've set "Calculation by formula" for the Turbulence).
Kind regards,
Daniele
Re: prescribing k and omega user profiles at inlet
Which version of the code are you using, and is this with a specific physical model ?
Is the velocity itself taken into account ?
daniele
Post by daniele »
After double checking, the routine actually works correctly, sorry for the useless loss of time.
Thank you for your help.
Daniele
