Variable Density with Frozen Rotor module
hyder4
Post by hyder4 »
Hello Developers,
I am running a closed cavity case with variable density (using ideal gas) to model free convection. Do I need to add any extra terms in the momentum equation to make it work ?
For example when solving the same problem with constant density I use Boussinesq approximation and add the following term in the momentum equation which works fine.
(6.28 KiB) Not downloaded yet
May I also ask what equations Code_saturne is resolving in frozen rotor module?
It will also be helpful to point out the subroutines it uses in frozen rotor.
hyder4
Re: Variable Density with Frozen Rotor module
Post by hyder4 »
I was wondering if there is any update on this?
Hyder.
Not many people on this forum seem to be familiar with this module/option (and I am not too sure of the theory regarding "frozen rotor", compared to the more costly but more explicit "transient" option.
In any case, to find the functions which are called here, "grep" is your friend.
