forbidden memory area access
Posted: Tue Jan 24, 2023 5:30 pm
by Boone11
Hi users,
I try to perform a computation on a mesh that is composed of both structured and unstructured hexa but the simulation fails before the first time step with the following error:
I think the error can be caused by the mesh since the same setup works well on another mesh (that is composed of only structured hexa).
I am using GMSH to perform the mesh (.msh). Below are some files that could help understanding the error.
As the mesh is quite big I uploaded it on filesender:
https://filesender.renater.fr/?s=downlo ... 5f76eda79a
Notice that there are warnings in the listing file about the mesh but I suppose that they are not responsible for the SIGSEV error since the error occurred before the first time step.
May you help me to understand and solve this issue ?
Re: forbidden memory area access
Posted: Wed Jan 25, 2023 5:41 pm
Do you have user-defined functions/subroutines ? According to your stack trace, the error could be there ?
Posted: Thu Jan 26, 2023 5:48 pm
by Boone11
Hi Yvan and thanks for your answer.
Yes I have user-defined subroutines. I perform other tests with a smaller mesh size to run the calculation in sequential and identify the issue. The computation failed due to a user-defined subroutine and more particularly when trying to calculate and store the two vertices of each edge. Here is the code:
Nseg = 36 ! number of edges+diagonals per cell
allocate(Vcell(ncelet,Nseg*2)) ! save the 2 vertices coordinates for each edge (for each cell)
allocate(Cptcell(ncelet)) ! counter of Vcell = 6(cells)*6(edges)*2(vertices per edge)=72
Vcell(:,:) = 0
Cptcell(:) = 0
! For all interior faces
! save the 2 vertices of each edge
do ifac = 1, nfac
iel1 = ifacel(1,ifac)
iel2 = ifacel(2,ifac)
do ii = ipnfac(ifac),ipnfac(ifac+1)-2
do jj = ii+1, ipnfac(ifac+1)-1
inod = nodfac(ii)
jnod = nodfac(jj)
Vcell(iel1,Cptcell(iel1)*2+1) = inod
Vcell(iel1,Cptcell(iel1)*2+2) = jnod
Cptcell(iel1) = Cptcell(iel1)+1
Vcell(iel2,Cptcell(iel2)*2+1) = inod
Vcell(iel2,Cptcell(iel2)*2+2) = jnod
Cptcell(iel2) = Cptcell(iel2)+1
This code works well on fully structured mesh. I do not see what causes trouble when the mesh is also containing non structural cells. Do you have an idea?
The obtained error is:
forrtl: severe (408): fort: (2): Subscript #2 of the array VCELL has value 73 which is greater than the upper bound of 72
Image PC Routine Line Source
libsaturne-5.3.so 00007FB02661A679 Unknown Unknown Unknown
cs_solver 000000000046E391 cs_user_f_initial 428 cs_user_initialization.f90
libsaturne-5.3.so 00007FB024A07353 inivar_ 197 inivar.f90
libsaturne-5.3.so 00007FB0244F67B2 caltri_ 577 caltri.f90
libcs_solver-5.3. 00007FB027EF7835 cs_run 429 cs_solver.c
libcs_solver-5.3. 00007FB027EF7B85 main 654 cs_solver.c
libc-2.28.so 00007FB012CC8CF3 __libc_start_main Unknown Unknown
cs_solver 000000000040E13E Unknown Unknown Unknown
solver script exited with status 152.
Thanks again
Posted: Fri Jan 27, 2023 1:04 am
You crash seems to be due to an incorrect estimation of arrays size/allocation. Are you sure about the number of edges + diagonals per cell ? Are you using only hexahedral elements ?
Recent versions of the code (v7.0, or v8.0-beta)have higher level operators (in C) allowing building various mesh adjacencies in a safer manner, so upgrading could be useful (and in any case, v5.3 has been retired since the release of v6.0 in September 2019).
Posted: Mon Jan 30, 2023 8:30 am
by Boone11
Hi Yvan and thanks.
Yes, this routine has been used for a long time in fully structured hexa mesh with success. Yes, according to GMSH there are only hexahedral elements.
I see that Cptcell(iel1) and Cptcell(iel2) sometimes become bigger than the allocated size of Vcell (Nseg*2=72) whereas they should not. I do not see a reason for this behavior.
For the moment, to unblock the situation, I used a if statement to allocate Vcell only if Cptcell(iel1) and Cptcell(iel2) are lower than 72. It works well on single processor but crashes on parallel computation. I do not see why in parallel computation issues occur. There are no error file created, the listing is suddenly interrupted after the partionning step. The slurm file gives:
Abort(17) on node 8 (rank 8 in comm 0): Fatal error in PMPI_Waitall: See the MPI_ERROR field in MPI_Status for the error code
I provide the end of the listing file and the
only partition_output file in attached file (i added the .txt extension to be able to upload it). The mesh output can be uploaded following the link:
https://filesender.renater.fr/?s=downlo ... 65d6b35bcb
Note that, if I remove the code provided in the message above there is no issue in parallel computation.
The moving to newer versions of the code is planned.
Posted: Mon Jan 30, 2023 6:28 pm
by Boone11
I think that I have found the reason of the error. In the listing file it is written:
Before joining
Number of cells: 71056
Number of interior faces: 202822
Number of boundary faces: 20692
Number of vertices: 83825
Global number of boundary faces selected for joining: 11040
Element selection successfully done.
Determination of possible face intersections:
bounding-box tree layout: 3D
Global number of intersections detected: 84780
Vertex-Vertex intersections: 79557
Other intersections: 5223
Joining operation is non-conforming.
Global number of new vertices to create: 7141
Equivalences broken for 0 edges.
Edge intersections and vertex creation done.
Pre-merge for 9930 global element couples.
Max size of a merge set of vertices: 3
Excessive transitivity for 0 set(s) of vertices.
Edge removed for 0 faces (global).
Join mesh cleaning done.
Merge vertices and mesh update done.
*** WARNING ***
Globally, 250 problem(s) found during the face splitting
66 open cycles,
184 edges traversed twice,
0 faces split into more than max_subfaces (= 200)
=> Eventually modify joining parameters
I think that I should not use the joining option. The user routines are not working with non conforming mesh.
