variable output on a slice
xiaoxue123
Post by xiaoxue123 »
I want to save some variables on a slice at a specific frequency. Attached is the cs_user_postprocess.c and the xml file. The mesh is defined in cs_user_postprocess_meshes, the variable output is defined in cs_user_postprocess_values. In the postprocess folder, geo file is generated but the variable pressure is not saved. Can you have a look at cs_user_postprocess to see if anything is wrong in it?
Xiaoxue
(7.53 KiB) Downloaded 606 times
setup_T.xml
(15.16 KiB) Downloaded 673 times
Re: variable output on a slice
Yes, your code in cs_user_postprocess_values is much too simplistic, and will probably lead to a crash for a postprocessing mesh not based on a selection of all cells.
There is an example specific to pressure on a surface mesh in the provided examples, so you should start with that example.
