processing on a slice
xiaoxue123
Post by xiaoxue123 »
Dear expert team,
I am trying to extract a slice and export pressure on it. In cs_user_process, the slice (x=0.01) is defined for postprocessing. But pressure is not exported although there is a geometry file "xxx.geo" generated in the postprocessing folder. Could you have a look at it? GUI file and run_solver.log are attached as well.
Thanks,
Xiaoxue
setup_T.xml
(15.6 KiB) Downloaded 669 times
run_solver.log
(73.61 KiB) Downloaded 672 times
cs_user_postprocess.c
(8.61 KiB) Downloaded 673 times
Re: processing on a slice
In any case, your user-defined function is coded dangerously : you try to call the output for all postprocessing meshes, including ones not limited to interior faces, which can cause a crash. You should at least have a test for the mesh id or category (as in the user examples) to make sure it matches.
