Convergence tool
jgd23
Convergence tool
Post by jgd23 »
I have install CS 7.2 on Ubuntu 22.04. I use the GUI of CS.
Convergence tool is not running during calculation. If I press the convergence tool button, nothing happens. I have follow Tjunction tutorial case.
How can I fix that?
niuniuaba
Re: Convergence tool
Post by niuniuaba »
You are not alone. I have the same problem.
  File "/home/wing/Apps/saturne-7.2.dbg/bin/code_saturne", line 94, in <module>
    retcode = cs.execute()
  File "/home/wing/Apps/saturne-7.2.dbg/local/lib/python3.10/dist-packages/code_saturne/base/cs_script.py", line 96, in execute
  File "/home/wing/Apps/saturne-7.2.dbg/local/lib/python3.10/dist-packages/code_saturne/base/cs_script.py", line 169, in trackcvg
    return cs_trackcvg.main(options, self.package)
  File "/home/wing/Apps/saturne-7.2.dbg/local/lib/python3.10/dist-packages/code_saturne/gui/cs_trackcvg.py", line 132, in main
    mv = MainView(cmd_package = pkg, cmd_case = case)
  File "/home/wing/Apps/saturne-7.2.dbg/local/lib/python3.10/dist-packages/code_saturne/gui/trackcvg/MainView.py", line 1275, in __init__
    self.timer.start(self.timeRefresh * 1000)
TypeError: arguments did not match any overloaded call:
  start(self, int): argument 1 has unexpected type 'float'
  start(self): too many arguments
Looks like some tricky incompatibility with python 3.10 because it works well with python 3.6.5 even in Ubuntu 22.04.
By the way, in python 3.10 $cspath is set to $cs_root_dir/local/lib/python3.10/dist-packages rather than $cs_root_dir/lib/python3.10/site-packages. It's not the cause of this problem but still it's weird.
jgd23
Post by jgd23 »
I have check the pathes of python 3.10, in the file code_saturne_build.cfg, it is written:
pythondir: /usr/local/local/lib/python3.10/dist-packages
pkgpythondir: /usr/local/local/lib/python3.10/dist-packages/code_saturne
There is nothing wrong, the folders exist
Do I need to use python 3.6.5 insted ? How can I do that?
Julien
I checked and found the problem, which is due to some timer quantity expecting an integer and receiving a floating-point value in recent PyQt versions (I did not check whether Python or PyQt is the cause).
The fix is pushed to GitHub for the master and v7.2 branches. So if your 7.2 build is based on a git clone, simply update and rebuild. Otherwise, the fix is simple, so you can do edit it manually if you really need to: https://github.com/code-saturne/code_sa ... 46e4bef607
niuniuaba
Post by niuniuaba »
The commit works for 7.2 in Ubuntu 22.04. By the way, 7.0 also has the same problem and modifying the python script manually solves the problem.
jgd23
Post by jgd23 »
I have update 2 files named MainView.py but the problem still persist.
Do I need to do something more?
Attached the MainView file
Julien
MainView.txt
(46.19 KiB) Downloaded 5867 times
jgd23
Post by jgd23 »
Still not working for me.
I change the 2 files MainView.py located in
- Home/Code_Saturne/code_saturne-7.2.0/python/code_saturne/gui/trackcvg
- Home/code_saturne/7.2.0/code_saturne-7.2.0/arch/Linux_x86_64/local/lib/python3.10/dist-packages/code_saturne/gui/trackcvg
Maybe I need to rebuild something?
Julien
Did you try running
"code_saturne trackcvg"
alone or only wih the GUI ?
If you run it alone, what error message do you have ?
jgd23
Post by jgd23 »
The error message is
julien@julien-virtual-machine:~/Travail/test_cyl1/RESU/20221119-0915$ code_saturne trackcvg
Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
File "/home/julien/code_saturne/7.2.0/code_saturne-7.2.0/arch/Linux_x86_64/bin/code_saturne", line 94, in <module>
File "/home/julien/code_saturne/7.2.0/code_saturne-7.2.0/arch/Linux_x86_64/local/lib/python3.10/dist-packages/code_saturne/base/cs_script.py", line 96, in execute
File "/home/julien/code_saturne/7.2.0/code_saturne-7.2.0/arch/Linux_x86_64/local/lib/python3.10/dist-packages/code_saturne/base/cs_script.py", line 169, in trackcvg
File "/home/julien/code_saturne/7.2.0/code_saturne-7.2.0/arch/Linux_x86_64/local/lib/python3.10/dist-packages/code_saturne/gui/cs_trackcvg.py", line 132, in main
File "/home/julien/code_saturne/7.2.0/code_saturne-7.2.0/arch/Linux_x86_64/local/lib/python3.10/dist-packages/code_saturne/gui/trackcvg/MainView.py", line 1277, in __init__
Julien
It seems your installation is still using the old (non-corrected) code. Did you reinstall after patching the sources ?
