Fluids mixture approach
Posted: Tue Oct 25, 2022 6:06 am
by samarul
Hello to you all!
I am just starting to use Code_Saturne (did some tutorials). My goal for the moment is to simulate the flow for two pipes (they join in one) with two fluids (different density and temperature). I created two meshes that I will join but I am lost as how to specify the different density for the initial mesh (in inlets I can add velocity and temperature).
Can you please guide me - documentation or an example?
Thank you!
Re: Fluids mixture approach
Posted: Tue Oct 25, 2022 8:32 am
by Antech
I think you can use 2 species. Open Species Transport under Calculation Features and add 2 species. Also, you need to add temperature scalar in Thermal Model window. You will have species concentrations (I don't know mass or volumetric) and temperature at any inlet. Then, to account for thermophysical properties effect, set Density, Viscosity e.t.c. in Volume Conditions => all_cells dialog to "User law", then give expressions for thermophysical properties that depend on species concentrations (please check if Saturne operates with mass or volumetric fractions).
I never used this approach but it should work. Saturne developers will clarify if there are some additional things to pay attention for.
Posted: Wed Oct 26, 2022 7:47 am
by samarul
Thank you for your answer. Your approach seems to be the right one. I am a little bit confused about choosing two species, should it be one for each mesh? And I can not find the "User law" option in the Volume Condition for all_cells.
Posted: Wed Oct 26, 2022 8:09 am
by Antech
I cannot suggest anything for multiple meshes, I never used more than one mesh with Saturne. But, actually, if you have a pipe junction, you only need one mesh for entire calculation domain. If you decide to use 2 meshes, you will need two species for both of them. Define unity concentration of the first component at one inlet and for the second component (specie) on another inlet. As if it's just one mesh.
To switch to User law, open "all cells" dialog, click "Constant" button in property group (for example, under Density) and select "user law" in dropdown list.
